Date/Time: Thu, 28 Mar 2024 23:31:45 +0000
[Programming Help] - space between bars
View Count: 489
[2019-12-10 04:56:03] |
jesslinn - Posts: 108 |
Is there any way to figure out (in ASCIL) the spacing between the bars in the various chart types (as opposed to the ChartBarSpacing which is the width of one bar and one inter bar space)? One way would be to read the settings from Global Settings/Graphics Settings/Other. This would give the width of some of the bar types as a percentage of the ChartBarSpacing. This does not appear to be possible but it would be great if it were. A use case for such access is to be able to line up GDI drawings with say the left side of the SC-drawn bars, or fit some text inside and existing bar display. Any chance that such a capability can be added? Date Time Of Last Edit: 2019-12-15 19:58:42
