Date/Time: Tue, 15 Sep 2026 12:22:51 +0000
Same custom study, more than one Sierra instance
View Count: 899
[2019-12-09 20:52:09]
User972768 - Posts: 166
Is there any limitation / recommendation on how to use persistent variables and dynamic memory management from the custom study when it is used in more than 1 instance at the same time?
The reason for my question is that somehow when I use my study only in 1 instance then everything is fine. If I open my study in more than 1 instance at the same time, it doesn't get FullRecalculation signal.
A bit more information about my dual-instance setup:
- 1st instance is connected to "SC Data" and enables DTC server
- 2nd instance uses 1st instance as source of historical data via DTC protocol
- My custom DLL is in Data directory on each instance
- there is a chartbook with single chart of ESZ19 and single copy of my study in it on 1st instance
- complete copy of this chartbook is in the Data directory of the 2nd instance
- If I open chartbook on 1st instance and it is the only active instance, then everything is fine
- If I open chartbook on 1st instance when 2nd instance is active and have similar book opened, then I have to do Chart>>Recalculate to activate my study. Otherwise I see chart updating, but my study is not doing anything.
Thank you
