Date/Time: Sat, 13 Sep 2025 04:47:07 +0000
Q re: using Windows Server to run Sierra Chart
View Count: 1544
[2019-12-09 20:45:59] |
TraderTen - Posts: 80 |
I want to run Sierra Chart on a cloud server with either Microsoft Windows v2019, 2016,or 2012. Will this work? |
[2019-12-10 17:23:42] |
T44 - Posts: 363 |
I've had Sierra Chart working on 2012 and 2016 on AWS, Google Cloud, and a local server.
[2019-12-10 17:53:43] |
Yes, any of those will work. Which you choose is a personal preference.
