Date/Time: Fri, 19 Apr 2024 05:21:08 +0000
sc.SetAlert Help as it doesn't seem to make sense?
View Count: 732
[2019-12-09 19:11:56] |
User92573 - Posts: 475 |
Dear Support Board I've just been working through some examples of simple ACSIL alerts but when I apply them I'm not getting the expected results. To keep things as simple as possible the alert studies are based on the default SC Donchian Channels, however, despite this being a simple test the outcome is not as expected. Obviously I'm making a basic error. I've set two different alert types and wanted to obtain an alert on crossing the highest/lowest from inside the channels using different methods. Any help would be appreciated. Date Time Of Last Edit: 2019-12-11 17:28:47
[2019-12-10 08:20:55] |
More testing and to the best of my knowledge I've followed Sierra Charts ACSIL instructions/example almost exactly - but still not working.
Date Time Of Last Edit: 2019-12-11 17:28:06
[2019-12-11 00:13:16] |
This code will not even compile: sc.PlaySoundW(HighestHighAlert.GetAlertSoundNumber() -1, "Highest High Alert"); //
You certainly did not get that from any Sierra Chart source. You cannot have the W after sound.And here is the documentation for sc.SetAlert which is extensive: sc.SetAlert() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-11 17:26:19] |
File attached.
Date Time Of Last Edit: 2020-02-07 15:29:20
