Date/Time: Thu, 28 Mar 2024 11:43:44 +0000
Rolling contract causes loss of chart settings
View Count: 935
[2019-12-09 07:54:36] |
User234172 - Posts: 44 |
If I manually change a chart from Z19 to H20 contract, then the session times etc for that chart default back to the global symbol settings. I have many charts for the same symbol and month, all with their own Chart Settings. They are all linked by Symbol, so that when I roll my main chart, all others roll. Now, every one of my charts has lost their specific chart-level settings that were required to drive the calculations that were imported from those charts. I now have to reset them all manually. It is a huge mess. For the future: is there any way for me to keep chart-specific settings when I am changing contract month within the same symbol root? Specifically the Chart Settings at the individual chart level of concern are: - session times - Use evening sessions I don't understand why these should change to symbol root default settings when I change the contract month of an existing chart. Date Time Of Last Edit: 2019-12-09 07:55:28
[2019-12-10 21:48:39] |
This is explained here: Global Symbol Settings: Setting of Intraday Chart Session Times Specifically refer to: Global Symbol Settings: Preventing the Changing of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-10 21:49:55
[2019-12-12 01:15:28] |
Letting you know in the next release we will prevent the chart Session Times from ever changing when there is just a change to the same symbol but a different contract month.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-12 01:15:56
