Date/Time: Wed, 24 Apr 2024 16:10:38 +0000
Chart Settings Window Now Only Appears In Top Left - Version 2021
View Count: 612
[2019-12-07 23:58:58] |
cmet - Posts: 534 |
Updated to 2021 and whenever I open the Chart Settings Window now it defaults to the top left corner of the screen. The position of this window used to be saved and would open in the last position it was used (ie: center of screen). Can you please restore that functionality? Having this happen on a large monitor requires clicking and dragging the window down everytime. Thanks |
[2019-12-08 05:01:57] |
Yes we know about this. It is explained here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1973 This will be resolved, in a few months. It really is extremely ridiculous that the operating system cannot even reliably display a dialog and then when we force the display it does not even center it. We will look into the ability to center one ourselves but that's not always going to work perfect because when there are multiple displays. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-08 05:03:05
