Date/Time: Wed, 01 May 2024 21:58:35 +0000
Little annoying bug in the installer
View Count: 548
[2019-12-07 05:20:35] |
User972768 - Posts: 166 |
Hello Support, Could you please pass to developers little request to fix installer? It always creates Desktop shortcuts regardless of the status of the "Add Desktop Shortcut" checkmark. Opposite to that "Add Start Menu Shortcut" doesn't create item in the start menu regardless of its setting. I use Windows 10 Home and just upgraded Sierra to v2021. Thanks and best regards |
[2019-12-11 13:54:26] |
User467974 - Posts: 2 |
I have the same problem.
[2019-12-11 20:20:52] |
User90125 - Posts: 715 |
Ditto.
