Date/Time: Fri, 19 Apr 2024 03:50:25 +0000
automatically draw a horizontal line for the opening price when a session starts
View Count: 888
[2019-12-06 21:11:00] |
Jay Greenlees - Posts: 15 |
Is there a setting that will automatically draw a horizontal line for the opening price when a session starts?
[2019-12-06 22:24:00] |
Sierra_Chart Engineering - Posts: 14006 |
Refer to this study: Daily OHLC Then you would set the Draw Style to Ignore for the Subgraphs for the High, Low, and Close. Refer to the following for this: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-09 01:06:58] |
Is there any way to place an order that is tied to the opening price of a session on ES? For example the U.S. RTH Session of S&P 500 Futures (ES) that opens at 930am EST Can you place an order before the open of the session that specifies to place a Buy Stop order that is ___ ticks above whatever the opening price is for the session or conversely that specifies to place a Sell Stop order that is ___ ticks below whatever the opening price is for the session |
