Date/Time: Thu, 28 Mar 2024 21:51:28 +0000
"Evaluate on Bar Close" is Checked - But Alert Sounds go off *Before Bar Close*, anywa
View Count: 621
[2019-12-06 18:48:55] |
gayer2428 - Posts: 75 |
I have configured simple alerts to trigger audio alerts. "Evaluate on Bar Close" is checked. But even before bar close alert sound is triggered anyway. Why is that? The audio alert is a custom sound I generated. Please resolve, as it creates premature alerts not warranted by the alert conditions & Evaluate on Bar Close specification. Thanks. |
[2019-12-07 07:06:16] |
This really cannot be true. There must be some other explanation. The bar before the last bar in the chart is continuously being evaluated.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-07 07:06:50
