Date/Time: Sat, 03 Oct 2026 07:36:50 +0000
Question on Crossfromabove/below
View Count: 1443
| [2019-12-06 15:06:51] |
| j4ytr4der_ - Posts: 947 |
I had been expecting crossfrombelow (for example, opposite for fromabove) to trigger if the candle opens above the trigger level, has a low that is below, and then closes above. This looks not to be the case and I just want to verify. Does crossfrombelow require the candle *open* below the trigger level and close above? And the reverse for crossfromabove? Is there any way to make it register if the low/high crosses first instead? Or would that just need to use a custom formula? |
| [2019-12-10 18:53:04] |
| User871277 - Posts: 34 |
You just need to change the formula. C = Last / Close H = High L = Low But maybe you may want to activate in the end alert on bar close, otherwise you may get several signals per bar. |
| [2019-12-10 19:17:29] |
Yes I ultimately just made my own formula. Was just curious if there was any optional way to adjust the behavior of the CROSSFROM functions.
