Date/Time: Fri, 29 Mar 2024 07:55:01 +0000
Mcclellan Oscillator
View Count: 798
[2019-12-06 14:55:21] |
JEM.TRADES - Posts: 16 |
Hi Support, Wondering what is the difference between the mcclellan oscillator and NISS-NYSE? Further, in your documentation it says it's normally used on historical charts. Will this oscillator lose effectiveness if I use it on a 30 min chart? will it be less reliable? What would be the main difference between using it on a Daily Vs a 30 min? I appreciate the help! |
[2019-12-06 18:52:47] |
You have to understand what the study does. It is documented here: McClellan Oscillator - 1 Chart Use your own judgment whether you think it is worth using or not. You can certainly use it on a 30 minute chart. That is perfectly fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
