Date/Time: Sat, 20 Apr 2024 08:30:27 +0000
Sierra 2021->data doesn't download into chartbook with the same name in NEW INSTANCE MODE
View Count: 1363
[2019-12-06 12:11:18] |
User33743 - Posts: 83 |
Hello, In ver. 2021 when i go into new instance i can choose chartbooks already created in standard mode but charts from those chartbooks stopped on "Download futures contract". When i rename same file and run on new instance than it works properly. Best Regards |
[2019-12-07 07:11:12] |
You are posting to this Support Board from an Expired account. If you have a paid account, then you would need to post from that account. You can ensure that you are using the correct account by selecting Help >> Support Board from within Sierra Chart, which will log you into the website with the account you are using within the Sierra Chart software.
