Date/Time: Thu, 25 Apr 2024 02:21:17 +0000
MULTIPLE ACCOUNTS with Denali data
View Count: 585
[2019-12-06 11:34:20] |
User993113 - Posts: 71 |
Hello, I opened an account with Dorman Trading. I want to use the Denali data feed for trading on the Dorman account. I would need to use two instances of my Sierra platform, powered by two separate accounts name (both Dorman), with two different subscriptions to the Denali feed data, and trading at the same time with two instances. It is possible? Thanks. |
[2019-12-06 15:19:10] |
Yes but really you just need one Sierra Chart account to do this. You can use the Denali data feed with two instances of Sierra Chart at the same time. No need for separate accounts or paying twice for the data feed.
