Date/Time: Thu, 28 Mar 2024 10:56:34 +0000
Cant Launch Sierra Chart in 64 bit version
View Count: 679
[2019-12-05 20:46:20] |
User401229 - Posts: 14 |
I was using Sierra earlier today fine. I shut down and came back 2 hours later and I cant launch SC. It works ok in 32 bit but not 64 bit. It does not even try to load just comes up with a windows error window saying SC has stopped working. Is this a common problem with an easy fix?. Nothing on my machine has changed no new software or updates. |
[2019-12-05 23:24:17] |
First thing we want you to do is to update to the current version. Download it from this page: Software Download Install Sierra Chart to: C:\SierraChart\ Let us know if you still have the problem. Perhaps there is a problem with the trade activity data. In any case we can figure it out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-05 23:24:44
