Date/Time: Fri, 19 Apr 2024 16:34:09 +0000
Work around for # of spreadsheet rows limitation for study data acquisition?
View Count: 586
[2019-12-05 17:15:06] |
User802127 - Posts: 6 |
I know how to get study data from the spreadsheet. But if the # of rows are increased too high it causes a performance hit. Is there a way to write data to a text file on the fly so that if I load 20 days of 1 min data I can get all of it through the spreadsheet? Using the replay function perhaps? If I limit the rows to 1000 the I will be able to get 2 and a half days or so of 1 minute data. There must be a way around this.
[2019-12-05 23:19:28] |
Have a look at: Write Bar and Study Data To File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-05 23:31:31] |
I have tried this. It doesn't work because study data is missing. See Missing ZigZag data on "Export Bar and Study Data to Text File" Trying to use the spreadsheet for a workaround as a result of the export not providing the study data. The data I need can be seen in the spreadsheet.
