Date/Time: Fri, 19 Apr 2024 01:28:34 +0000
ACSIL data function
View Count: 610
[2019-12-05 15:47:20] |
User884396 - Posts: 26 |
Hello support, is it possible in ACSIL to get the earnings date of a stock in order to alert before it happens? I have seen several post talking about this but there is no clear answer.
[2019-12-05 23:20:23] |
No, this is not supported as a built-in study.
[2019-12-09 14:45:56] |
I dont need a study, i want to know if there is a function to get that from the stock data.
[2019-12-09 17:55:58] |
John - SC Support - Posts: 30953 |
No, there is not a function to get this information. You would need to build that part of the functionality externally.
