Date/Time: Thu, 25 Apr 2024 01:55:56 +0000
[User Discussion] - Workspace
View Count: 687
[2019-12-05 15:34:24] |
User737360 - Posts: 23 |
Hi, if I want to open a workspace then it says "Symbol settings not found for current service", what can I do? |
[2019-12-05 23:25:52] |
First thing to do is to make sure the symbols are set correctly by using this command on the Edit menu: Edit Menu: Edit >> Translate Symbols To Current Service We see you are using CTS. So do you have a CTS trading account? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
