Date/Time: Tue, 23 Apr 2024 20:32:20 +0000
VAs/POCs based on Volume
View Count: 579
[2019-12-05 13:36:25] |
MarcOh - Posts: 162 |
Hey guys, thx for your time. What is the right choice in perpective of VAH and VAL respectively cont. contract, to see the same VAs like in "ATAS" ordeflow software. What is the official right way? Any suggestion? Regards Marco |
[2019-12-08 04:28:22] |
Volume Value Area and POC lines are supported. Refer to: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines Also refer to: TPO Value Area Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-08 04:28:52
