Date/Time: Fri, 26 Apr 2024 05:19:05 +0000
ASX24
View Count: 541
[2019-12-04 15:11:31] |
Verticalchaser - Posts: 4 |
ok, one last question, could i get ASX24 exhange as DATA ONLY from Dorman CQG, not trading , reason is i need the Dorman CQG to run another platform...... what i am hoping is to have two feeds on my SC, one being the TT data and trading feed for the CME products - already set up and a second being the Dorman CQG ( data only ) for ASX24, both these feeds give best depth of market to see order book, this would get rid of my current data provider - iqfeed which has a terrible depth of market feed at just 10 prices up and down |
[2019-12-04 15:19:05] |
If you have a trading account set up through the CQG system and it is authorized for ASX data, then Sierra Chart can access that data through the CQG Web API interface. Technically this can be done but check with Dorman. Or you could just use CQG for all your trading instead of TT. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-04 15:19:25
[2019-12-04 21:12:14] |
ok thank you , i will investigate
