Date/Time: Tue, 04 Nov 2025 18:18:13 +0000
[User Discussion] - Flex Renko and Spreaedsheet Study
View Count: 2856
[2013-04-12 12:27:01]
Trader10239 - Posts: 4
I am using Flex Renko chart and have attached a Spreadsheet Study. I notice the OHLC price on the spreadsheet does not correspond to the one on the chart (see attached screenshot). Please help.
Thanks.
Regards
Date Time Of Last Edit: 2013-04-12 12:29:31
imageFlexRenko.jpg / V - Attached On 2013-04-12 12:25:11 UTC - Size: 387.96 KB - 1018 views
[2013-04-12 21:39:09]
vegasfoster - Posts: 444
Someone correct me if this is wrong, but I read somewhere else that as of now, it's using the actual OHLC, so the only way is to use study subgraph add, add zero, and reference the renko open or renko close figure.
Date Time Of Last Edit: 2013-04-12 21:39:24
[2013-04-12 21:54:20]
We are adding a new study to the next version named "Renko Visual Open/Close Values" that you can add to the chart to access these values through the study spreadsheet columns.
[2013-04-12 21:55:23]
Sawtooth - Posts: 4285
Support has indicated they will create a study that will output the native Renko OHLC to the spreadsheet.
Flex Renko Open difference
