Date/Time: Mon, 03 Feb 2025 18:25:57 +0000
Ghost order
View Count: 587
[2019-12-02 19:47:40] |
User450179 - Posts: 105 |
there is a ghost order being filled on my charts only on my charts when i click show trades on charts which throws off all of my buys and sells on the chart thanks |
[2019-12-03 00:08:41] |
Refer to this section here about this: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
