Date/Time: Fri, 26 Apr 2024 14:54:22 +0000
[Programming Help] - Bid ask prices study will not show
View Count: 934
[2019-12-02 18:00:35] |
User856584 - Posts: 2 |
For some reason when I add this study to a page I see a very fast flicker with the line graph plotted but then it goes away and all I see is the big ask of current second at right of page. Please help!
[2019-12-03 00:22:14] |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-17 19:05:59] |
kasabo - Posts: 27 |
Dear support, My Intraday Data Storage Time Unit is 1 Tick and my chart update interval is 900ms. I would like to view Bid and Ask Prices on the values scale. I have a chart with Intraday chart bar period setting is "number of trades per bar".I added Bid Ask Prices on this chart. Then inside the same chartbook, I carried this study to other charts by using Study/Price Overlay Study. When compared to directly adding Bid Ask Prices Study to other charts, does this approach add value? or It just consumes unnecessary processing power from my computer? Thank you. |
