Date/Time: Tue, 15 Sep 2026 23:31:15 +0000
Accessing "Initial Simulated Account Balance" from ACSIL?
View Count: 945
| [2019-12-02 13:44:47] |
| BenjFlame - Posts: 353 |
Hi, is it possible to access the value set in "Initial Simulated Account Balance" from ACSIL? If not, please guide me in the proper ACSIL direction so I can set a variable amount with the following requirements: - It must be set manually, and will not change unless I do need to change it manually which will be infrequent. - It must be accessible from any study. - It must easily be modifiable (like with "input name" of a study). Should I set a global variable for this, and make it an input? |
