Date/Time: Mon, 03 Feb 2025 17:14:58 +0000
No more level II
View Count: 564
[2019-12-02 13:42:26] |
lpfin123 - Posts: 59 |
Good morning, I only see the current bid/ask depth on my DOMs. I would like to see the full depth. I never had this issue before. I don't know if it is related to the fact that I switch my data from the Sierra Feed to Denali. Thank you, |
[2019-12-02 13:45:45] |
Add sufficient credit to your Sierra Chart account and then activate the Denali exchange data feed here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed You can add credit here: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit If you need help activating the data feed let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-02 13:45:52
[2019-12-02 13:57:03] |
Adding money makes a lot of sense... I usually receive a message when I open SC that I need to add money. It wasn't the case this month. Was this a one time thing that I didn't receive the message or should I put that reminder somewhere? |
[2019-12-02 13:59:49] |
I usually receive a message when I open SC that I need to add money. It wasn't the case this month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
