Date/Time: Wed, 05 Nov 2025 05:51:59 +0000
TTNet vs regular TT FIX
View Count: 2009
[2013-12-25 14:04:11]
ronghuax - Posts: 12
Hello, I'm trying to decide between AMP TTNet vs regular TT FIX from other brokers. What's the big difference, or are they basically the same?
Thank you!
[2013-12-26 00:23:11]
From our perspective, they are basically the same.
[2013-12-26 01:40:22]
User51517 - Posts: 58
Correct me if I'm wrong, but from what I've heard, TTNet is managed by TT, while TT Fix is managed by FCM. Therefore the quality of your data is dependent on the infrastructure of your FCM.
Date Time Of Last Edit: 2013-12-26 01:48:56
[2013-12-26 01:48:16]
If you are looking for quality data, we recommend using our own data feed:
http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php
