Date/Time: Mon, 03 Feb 2025 17:13:52 +0000
HI There is a problem with the CHART graph There is a delay of the graphs Facing the DOM..
View Count: 524
[2019-12-02 03:50:36] |
User752881 - Posts: 9 |
HI There is a problem with the CHART graph There is a delay of the graphs Facing the DOM Of TRANSACT software Regards ELAD |
[2019-12-02 04:48:37] |
You are using the Transact provided data feed. For more information about this problem, refer to: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SolvingLaggingDataFeed_StoppingDataFeed_MissingDataIssues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
