Date/Time: Thu, 19 Sep 2024 16:06:38 +0000
v1064 the back adjustments option
View Count: 1876
[2013-12-25 06:01:44] |
ganz - Posts: 1048 |
Hello SC Support v1064 non_CLR 1. Continuous Futures Contract && Back Adjust Continuous Contract Data are disabled http://www.sierrachart.com/image.php?l=1387950866850.png 2. Continuous Futures Contract && Back Adjust Continuous Contract Data are enabled http://www.sierrachart.com/image.php?l=1387950943708.png Please look at the ending date/time for the charts. These are the same charts with that options are enabled/disabled and nothing else have been changed. With best regards. |
[2013-12-25 07:37:36] |
The basic problem is there are no rollover rules defined for the CTS FIX symbols. Just give us about a couple of hours to work on this for the 6E. Later in the week we will set the others up. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-25 07:37:55
[2013-12-25 09:25:16] |
SC Support. 1. http://www.sierrachart.com/image.php?l=1387963425912.png 2. http://www.sierrachart.com/image.php?l=1387963458591.png ty. |
[2013-12-25 09:31:39] |
SC Support. 6EZ3 http://www.sierrachart.com/image.php?l=1387963890313.png |
[2013-12-25 09:32:51] |
What you appear to be showing is that the rollover was 1 day late compared to when the majority of the volume rolled over to the next contract. You can adjust the rollover settings through Global Settings >> Symbol Settings. Set the Number of Business Days to 3. We will also be adding volume-based rollovers. But that probably will not be ready for about another month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-25 09:34:17
[2013-12-25 11:27:58] |
SC Support. I've used IQFeed before SC CME RtDf has started and now I see how to set the rollover rule for a ticker using SC the links if anybody is interested in http://www.iqfeed.net/symbolguide/index.cfm?symbolguide=guide&displayaction=support§ion=guide&web=iqfeed&guide=commod&web=IQFeed&symbolguide=guide&displayaction=support§ion=guide&type=cme_GBX&type2=cmemini http://forums.iqfeed.net/index.cfm?page=topic&topicID=3485 Global Settings >> Symbol Settings --> Rollover --> Rollover Rule Thank you. Date Time Of Last Edit: 2013-12-25 11:31:37
