Date/Time: Mon, 03 Feb 2025 17:09:36 +0000
Trade Window flickering
View Count: 759
[2019-12-01 20:40:00] |
User138602 - Posts: 169 |
Since i updated to the latest version my attached trade windows flicker and its kinda annoying. Please fix this as soon as possible. Best Regards |
[2019-12-01 23:14:46] |
We are aware of this. We will be resolving it over the next couple of days. It relates to when using the Associated/Watch Symbol list on the Control Bar.
[2019-12-02 07:41:39] |
I can confirm that. After removing the watchlist from the control bar, the flickering is gone.
[2019-12-02 13:30:17] |
This problem will be resolved today by us. We are working on it now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-02 13:30:23
