Date/Time: Thu, 19 Sep 2024 16:16:57 +0000
bitcoin: bitstamo data
View Count: 1428
[2013-12-25 01:28:35] |
yoytu - Posts: 59 |
i dont know if you made any changes but the data prior to 07/12(dec)/2013 dont support delta volume information anymore
BTC-BSTMP 1 day #5 41633.061.png / V - Attached On 2013-12-25 01:28:17 UTC - Size: 43.46 KB - 444 views |
[2013-12-25 03:51:11] |
Yes, this makes sense because we re-download the historical data from another source to fill in gaps and to get more history.
[2013-12-25 09:00:39] |
yoytu - Posts: 59 |
can be fixed ?
[2013-12-25 09:35:20] |
No. There is no practical solution to this.
