Date/Time: Mon, 03 Feb 2025 17:02:56 +0000
DOM update disparity between instances
View Count: 660
[2019-11-29 01:19:07] |
User234172 - Posts: 44 |
Using the "New Instance" DTC sharing method here Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance I have numerous cases of the same DOM: 1. Server SC instance, attached 2. Server SC instance, detached 3. Client SC instance, attached 4. Client SC instance, detached Comparing various DOM cases, I find that there is a lag visible to the eyeball between updates, between many combinations of cases. There is even a lag between a duplicate DOM, both attached, within the same SC instance and chartbook. PC processor at 20% and RAM at 60% I have a lot of charts open, maybe 8 are detached, and maybe 8 DOMs in total. Three symbols. This is part of dev work, not operational. |
[2019-11-29 21:33:26] |
Check the Chart Update Interval setting to make sure they are the same among all those charts: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) But certainly there will be momentary differences. You cannot expect to see the exact same values among each of the market depth displays at the exact instant in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-29 21:34:33
