Date/Time: Thu, 19 Sep 2024 16:27:23 +0000
How can I take chart out of the frame and put them in another part of my screen (I have 2 monit
View Count: 1227
[2013-12-24 15:40:10] |
User68336 - Posts: 1 |
Dear sirs, I am a new commer of sierra chart and can take my chart out of your frame please help me CTS said that I must ask you teh question: how to put 4 charts on a monitor without your frame. Thanks yuan Date Time Of Last Edit: 2013-12-24 15:41:43
[2013-12-24 16:15:28] |
ganz - Posts: 1048 |
User68336 Window -> Detach/Attach Window |
[2013-12-24 21:19:09] |
Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-24 21:19:55] |
We have also given your account a time extension so you have more time to try Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-24 21:20:06
