Date/Time: Thu, 19 Sep 2024 16:44:20 +0000
Unlock Drawing
View Count: 1323
[2013-12-24 14:25:36] |
User97146 - Posts: 12 |
On one of my computers after I set a line, I can lock the drawing by right clicking on the mouse, I can unlock or lock. On my main computer I do not have this option...please help thanks Vincent I do not have the Lock Drawing Tool...... Date Time Of Last Edit: 2013-12-24 17:32:13
[2013-12-24 16:10:34] |
You need to add the command through Global Settings >>Customize Chart Drawing Menu.
