Date/Time: Sun, 19 May 2024 04:36:42 +0000
Delay When Moving Around Charts
View Count: 524
[2019-11-27 16:32:19] |
User364163 - Posts: 1 |
Hi In the last week and a half my Sierra Chart is slow to respond. This happens when: I try to scroll up/down on price bar Scrolling across charts Trying to draw line etc every function I use IQ Data feed. When I disconnect to IQ data feed everything works normally. Reconnect and lag is back. I have contacted IQ, several checks have been made and no faults found. I have had an engineer out to my computer and says is working correctly with plenty of storage space. I have removed Sierra and have downloaded again from the beginning and still the lag occurs. Any ideas please - getting desperate. Many thanks Paul |
[2019-11-28 03:38:22] |
We need you to provide the Chartbook and then we can have a look at this and see if we can reproduce this. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Also refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-28 03:38:28
