Date/Time: Thu, 19 Sep 2024 16:37:14 +0000
External Connections - ACSIL
View Count: 1431
[2013-12-24 10:54:49] |
Lavie - Posts: 10 Invalid SC Account Name. |
Hi, Is it possible to send data to a study, from an external process? If yes, than please attach an ACSIL code that can receive data. If No, than how can i connect to a study? Ariel |
[2013-12-24 17:09:41] |
Yes. Some methods to consider would be a network socket or reading from a data file. Both of these can be used from an ACSIL study. Exact implementation details are outside the scope of our support although reading from a file is a very simple and reliable method. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
