Date/Time: Fri, 04 Apr 2025 21:21:05 +0000
Charting - Different time scales for different series
View Count: 901
[2019-11-27 01:01:57]
User689221 - Posts: 20
Is it possible to offset different data series on the same chart by several periods?
I need the ability to move select series by flexing their starting points while keeping the series the same (i.e. move Jan-1 to Feb-1 by shifting all data points by 31 days) - for select series while keeping other series constant.
Put differently, freeze some series and allow other series to shift horizontally.
Thank you!
[2019-11-29 02:11:53]
We will look into adding support for this with the Study/Price Overlay study. Please allow us about two weeks to look into this.
[2019-11-29 05:19:42]
Thank you SO MUCH for considering this request!
The idea here is to determine relative time lag (expressed in days or hours depending on the time scale) between different assets' inflection points by aligning different series horizontally. The ability to invert series is very useful for this analysis as it allows to better align otherwise top/bottom inflection points.
This analysis can be done as follows:
1) by plotting one user-selected period's values only (can be entered as from-to dates format),
2) by plotting historical averages for each asset class (5-year averages, for example) while including current period's values in these averages, and
3) by plotting historical averages for each asset class while excluding current period's values from these averages, and instead showing current period as a separate series
For 2) and 3) the time scale will need to be expressed in Trading Days rather than in calendar dates.
Thank you again!!
[2024-03-01 18:51:39]
User192715 - Posts: 3
Hi, Any update on this?.
I looking forward to use it to plot seasonality.
Eg: Time scale based on number of trading days/hours/mins instead of calendar dates.
[2024-03-12 18:26:17]
Sierra_Chart Engineering - Posts: 19075
There has been no work on this, and we do not think we will be doing it.
This is not so simple.
