Date/Time: Sun, 19 May 2024 00:36:58 +0000
DPL showing inacuratevalues
View Count: 632
[2019-11-26 18:28:01] |
User842104 - Posts: 3 |
Hi I have downloaded the latest version of Sierra chart (2013 64 bit) and since then DPL numbers are showing inaccurate numbers. I have selected points as the display format and it shows 53 points when I actually made 6 points. Average fill price shows infinity. Please let me know what the fix is. I am open to downgrade to a lower version if needed. THanks |
[2019-11-26 20:23:20] |
This is explained in detail here: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
