Date/Time: Sun, 19 May 2024 07:51:13 +0000
New Computer and Windows 10
View Count: 948
[2019-11-26 17:03:10] |
wingz - Posts: 121 |
Like thousands of other people, I'm being forced to switch from Windows 7 to Windows 10 soon. I'm going to buy a new computer with Windows 10 on it. I'll have to get Sierra onto the new computer. I'd like to just have a duplicate of my current Sierra program with all the same charts and data on the new computer. Can you please tell me the easiest and most efficient way to do this please.
[2019-11-26 17:21:09] |
Microsoft is not forcing you to update from Windows 7. You can stay there and we recommend that so long as your computer hardware supports Windows 7. To do what you want, refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-26 23:38:58
[2019-11-26 23:12:31] |
I put a question on the support board about getting a duplicate copy of my Sierra program from Windows 7 to Windows 10. You included a link in your reply. When I click on the link I get an error message (404) that says this page is not available. That link was supposed be Help topic 15 which, I hope, will give me instructions on how to get a duplicate copy of my Sierra program into Windows 10.
[2019-11-26 23:39:14] |
We apologize. Here is the correct link: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
