Date/Time: Sun, 19 May 2024 00:36:59 +0000
Windows 10 version home vs pro?
View Count: 603
[2019-11-26 15:31:04] |
grayfrog - Posts: 35 |
Searched the forum and apparently no one has had a question quite this simple/dumb..... Does it matter if you are using Windows 10 home or pro? |
[2019-11-26 15:41:09] |
No it does not matter.
[2019-11-26 15:54:34] |
Thank you. Does it matter if you use Parallels desktop or do you need to use Parallels Pro? |
[2019-11-26 17:37:21] |
We do not think this matters one way or the other.
