Date/Time: Sun, 19 May 2024 02:17:46 +0000
analysis tab didnt worked
View Count: 478
[2019-11-26 13:08:11] |
User440470 - Posts: 1 |
when i pressed analysis tab,all of the sudden the chart freeze. none of the tab can be pressed.and the message log showed up with the last message "gbpusd(m)15m #10|caught on unhandled exeception in c_chart::window proc.message:32769,w param
[2019-11-26 14:49:58] |
Are you able to reproduce this problem more than one time? We want you to restart Sierra Chart first before trying again. We want you to run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Let us know if you still have the problem in Safe Mode. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
