Date/Time: Sun, 19 May 2024 01:11:02 +0000
dom trading
View Count: 565
[2019-11-25 15:50:20] |
User749229 - Posts: 7 |
hello i am having issues trading from the DOM , it worked before but now it gives me an error (selected time in force not supported), if i open trade window for dom and trade from there it works .can you let me know what might be the problem.thanks
[2019-11-25 23:06:35] |
The general issue is that your Time in Force setting on the Trade Window associated with the Trading DOM you are trading from, is not valid with the trading service being used. Refer to the following for the Time in Force: Basic Trading and the Trade Window: Main >> TimeInForce (Time in Force): Most importantly also refer to this section to make sure you are setting this on the correct Trade Window: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-25 23:06:57
