Date/Time: Sun, 19 May 2024 01:11:01 +0000
Migration of NT8
View Count: 928
[2019-11-25 14:12:06] |
Zeroone - Posts: 11 |
hi i need have migration of ninja trader; but i not know the ticks bar equivalent of sierrachart; can you helpme
[2019-11-25 15:45:07] |
User99735 - Posts: 234 |
Hi, "Number of Trades per Bar" is equivalent to NT's Tick Bars, further details at https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NumberOfTrades. We provide services for migration of NT Indicators/Strategies to SC, if you need such services, do message back. Regards Vivek |
[2019-11-25 17:51:29] |
Yes this is called Number of Trades Per Bar and is a Chart Setting: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NumberOfTrades. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-26 11:49:06] |
Hi, i need put one mark with the picture in crossover medias
AnotaciĆ³n 2019-11-26 114448.jpg / V - Attached On 2019-11-26 11:47:33 UTC - Size: 15.8 KB - 273 views Attachment Deleted. |
[2019-11-26 12:00:09] |
Hi, Please provide the details of the indicators you are using, the crossing of which is marked in the screenshot. If possible please provide the rules of the 'marks' to be created at each crossover. Regards Vivek |
[2019-11-26 12:18:19] |
The picture is NT8, i Need create this market with EMA 80 cross with EMA 20
Date Time Of Last Edit: 2019-11-26 12:18:49
[2019-11-26 12:19:32] |
Exist this indicator or I need programming for this
[2019-11-26 12:59:21] |
Hi, EMA indicator is available in SC. Will take up further in direct messages. Regards Vivek |
[2019-11-26 12:59:38] |
Ackin - Posts: 1865 |
Yes, Try:Moving Average Crossover Moving Average Crossover |
