Date/Time: Sun, 19 May 2024 06:51:43 +0000
connect
View Count: 539
[2019-11-25 11:46:55] |
User372626 - Posts: 59 |
Hi: I live in China and have network latency,especially Chicago trading time.How can I set up a proxy server to log in the trading server to reduce latency. Thank you! |
[2019-11-25 13:27:56] |
Are you just experiencing latency with market data? Are there any issues or delays with trading?
[2019-11-25 14:51:47] |
Yes,I experiencing latency with market data,I cannot trade.
[2019-11-25 15:01:34] |
We can set up a market data real-time relay either in London, Germany or Singapore. What do you think you would want to use? Or we could do all of them and you can try any.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-25 15:01:48
[2019-11-26 14:36:03] |
Reading Internal Order ID file. | 2019-11-26 18:40:15.998 Reading Trade Orders file. | 2019-11-26 18:40:16.079 Reading Trade Positions file. | 2019-11-26 18:40:16.079 Reading Account Balance file. | 2019-11-26 18:40:16.080 UDPListener (1420). Port 22904 | Listening on UDP port 22904. | 2019-11-26 18:40:16.101 Software version: 2011 64-bit | 2019-11-26 18:40:16.101 Usage end date: 2020-07-07 | 2019-11-26 18:40:16.101 Enabled for: Advanced Features 2. | 2019-11-26 18:40:16.101 Enabled for: Sierra Chart Historical Data Service. | 2019-11-26 18:40:16.101 Enabled for: Denali Real-Time Exchange Data Feed. | 2019-11-26 18:40:16.101 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2019-11-26 18:40:16.101 Enabled for exchange2: CME | 2019-11-26 18:40:16.101 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-11-26 18:40:16.101 Current selected Data/Trading service: SC Futures Order Routing/Data | 2019-11-26 18:40:16.101 Custom symbol settings values: enabled | 2019-11-26 18:40:16.101 Chart Update Interval: 500 | 2019-11-26 18:40:16.101 Intraday Data Storage Time Unit: 0 | 2019-11-26 18:40:16.101 Time Zone: +08:00:00 (HKT+08) | 2019-11-26 18:40:16.101 2019-11-26 18:40:16 Local computer time | 2019-11-26 18:40:16.101 2019-11-26 10:40:16 Local computer time in UTC | 2019-11-26 18:40:16.101 2019-11-26 18:40:16 Local computer time in SC Time Zone | 2019-11-26 18:40:16.101 2019-11-26 10:40:15 Server time in UTC | 2019-11-26 18:40:16.101 Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-11-26 18:40:16.101 Program path: F:\SierraChart\ | 2019-11-26 18:40:16.101 Data Files path: F:\SierraChart\Data\ | 2019-11-26 18:40:16.101 OS Version Number: 10.0 | 2019-11-26 18:40:16.101 Locale Setting: C | 2019-11-26 18:40:16.101 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-11-26 18:40:16.101 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures.dtc.trading. Request ID: 1. | 2019-11-26 18:40:16.117 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-11-26 18:40:16.182 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-11-26 18:40:16.396 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-11-26 18:40:16.396 Received 5 login tokens. | 2019-11-26 18:40:17.635 Symbol settings MD5 received. Request ID: 1. | 2019-11-26 18:40:17.694 Requested symbol settings for service code sc_futures.dtc.trading. Request ID: 2. | 2019-11-26 18:40:17.694 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2019-11-26 18:40:22.663 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2019-11-26 18:40:23.221 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2019-11-26 18:40:23.221 SC Futures Order Routing/Data | Connected to server. | 2019-11-26 18:40:23.545 SC Futures Order Routing/Data | Starting socket receive thread. | 2019-11-26 18:40:23.545 SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-11-26 18:40:23.545 SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2019-11-26 18:40:26.629 SC Futures Order Routing/Data | Sending logon request message. | 2019-11-26 18:40:26.629 SC Futures Order Routing/Data | Received logon response. | 2019-11-26 18:40:26.876 SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2019-11-26 18:40:26.876 SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2019-11-26 18:40:26.876 SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2019-11-26 18:40:26.877 SC Futures Order Routing/Data | Trading is supported. | 2019-11-26 18:40:26.877 SC Futures Order Routing/Data | Order cancel and replace is supported. | 2019-11-26 18:40:26.877 SC Futures Order Routing/Data | OCO Orders supported. | 2019-11-26 18:40:26.877 SC Futures Order Routing/Data | Bracket Orders supported. | 2019-11-26 18:40:26.877 SC Futures Order Routing/Data | Connected to data and trading server. | 2019-11-26 18:40:26.877 Triggering next historical data download in queue. | 2019-11-26 18:40:26.877 Triggering next historical data download in queue. | 2019-11-26 18:40:26.877 Triggering next historical data download in queue. | 2019-11-26 18:40:26.877 Triggering next historical data download in queue. | 2019-11-26 18:40:26.877 Symbol settings received. Request ID: 2. | 2019-11-26 18:40:31.274 6BZ19_FUT_CME 30 Min #1 | Reloading chart. | 2019-11-26 18:40:49.457 6BZ19_FUT_CME #3 | Reloading chart. | 2019-11-26 18:40:49.561 6BZ19_FUT_CME [C] Daily #4 | Reloading chart. | 2019-11-26 18:40:49.662 6BZ19_FUT_CME [C] Daily #4 | Performing historical Daily data download for symbol 6BZ19_FUT_CME starting at last date in file. | 2019-11-26 18:40:49.800 Starting DelayedDownloadMonitoringTimer | 2019-11-26 18:40:49.800 Starting HDTimeoutTimer | 2019-11-26 18:40:49.800 Added historical Daily data request for 6BZ19_FUT_CME to the queue. | 2019-11-26 18:40:49.800 Triggering next historical data download in queue. | 2019-11-26 18:40:49.800 6BZ19_FUT_CME [C] Daily #4 | Waiting for historical downloads to complete with the IDs: 1, | 2019-11-26 18:40:49.999 6BZ19_FUT_CME #5 | Reloading chart. | 2019-11-26 18:40:50.013 6BZ19_FUT_CME [C] 1 Day #9 | Reloading chart. | 2019-11-26 18:40:50.113 6BZ19_FUT_CME 5 Min #6 | Reloading chart. | 2019-11-26 18:40:50.238 6BZ19_FUT_CME 0.0010 Range #2 | Reloading chart. | 2019-11-26 18:40:50.347 6BZ19_FUT_CME 1000 Volume #7 | Reloading chart. | 2019-11-26 18:40:50.454 6EZ19_FUT_CME 30 Min #1 | Reloading chart. | 2019-11-26 18:40:50.597 6EZ19_FUT_CME #3 | Reloading chart. | 2019-11-26 18:40:50.706 6EZ19_FUT_CME [C] Daily #4 | Reloading chart. | 2019-11-26 18:40:50.843 6EZ19_FUT_CME [C] Daily #4 | Performing historical Daily data download for symbol 6EZ19_FUT_CME starting at last date in file. | 2019-11-26 18:40:50.970 Added historical Daily data request for 6EZ19_FUT_CME to the queue. | 2019-11-26 18:40:50.970 6EZ19_FUT_CME [C] Daily #4 | Waiting for historical downloads to complete with the IDs: 2, | 2019-11-26 18:40:51.232 6EZ19_FUT_CME #5 | Reloading chart. | 2019-11-26 18:40:51.243 6EZ19_FUT_CME 0.00050 Range #8 | Reloading chart. | 2019-11-26 18:40:51.429 6EZ19_FUT_CME [C] 1 Day #9 | Reloading chart. | 2019-11-26 18:40:51.531 6EZ19_FUT_CME 5 Min #6 | Reloading chart. | 2019-11-26 18:40:51.649 6EZ19_FUT_CME 5 Min #10 | Reloading chart. | 2019-11-26 18:40:51.784 6EZ19_FUT_CME 1000 Volume #12 | Reloading chart. | 2019-11-26 18:40:51.903 6EZ19_FUT_CME 60 Min #2 | Reloading chart. | 2019-11-26 18:40:52.024 6EZ19_FUT_CME 240 Min #7 | Reloading chart. | 2019-11-26 18:40:52.811 ESZ19_FUT_CME [C] 1 Day #2 | Reloading chart. | 2019-11-26 18:40:53.033 ESZ19_FUT_CME 5 Min #3 | Reloading chart. | 2019-11-26 18:40:53.112 ESZ19_FUT_CME #5 | Reloading chart. | 2019-11-26 18:40:53.365 ESZ19_FUT_CME [C] 2.50 Range #7 | Reloading chart. | 2019-11-26 18:40:53.500 ESZ19_FUT_CME #6 | Reloading chart. | 2019-11-26 18:40:54.308 ESZ19_FUT_CME [C] 5 Min #4 | Reloading chart. | 2019-11-26 18:40:54.498 MESZ19_FUT_CME 15 Min #8 | Reloading chart. | 2019-11-26 18:40:54.717 ESZ19_FUT_CME 15 Min #1 | Reloading chart. | 2019-11-26 18:40:54.967 ESZ19_FUT_CME #5 | Reloading chart. | 2019-11-26 18:40:55.500 ESZ19_FUT_CME [C] Daily #6 | Reloading chart. | 2019-11-26 18:40:55.792 ESZ19_FUT_CME [C] Daily #6 | Performing historical Daily data download for symbol ESZ19_FUT_CME starting at last date in file. | 2019-11-26 18:40:55.904 Added historical Daily data request for ESZ19_FUT_CME to the queue. | 2019-11-26 18:40:55.904 ESZ19_FUT_CME [C] Daily #6 | Waiting for historical downloads to complete with the IDs: 3, | 2019-11-26 18:40:56.376 ESZ19_FUT_CME #7 | Reloading chart. | 2019-11-26 18:40:56.386 ESZ19_FUT_CME 5 Min #8 | Reloading chart. | 2019-11-26 18:40:56.581 ESZ19_FUT_CME 1000 Volume #11 | Reloading chart. | 2019-11-26 18:40:56.760 ESZ19_FUT_CME 5 Min #4 | Reloading chart. | 2019-11-26 18:40:56.950 ESZ19_FUT_CME 60 Min #10 | Reloading chart. | 2019-11-26 18:40:57.132 ESZ19_FUT_CME 2.50 Range #9 | Reloading chart. | 2019-11-26 18:40:57.323 Mapping 6BZ19_FUT_CME to 6BZ19. Service code: cme | 2019-11-26 18:40:57.368 HD Request # 2 | Downloading Historical Daily chart data for 6BZ19_FUT_CME. Starting date: 2019-11-22. Service: sc_futures.dtc.trading | 2019-11-26 18:40:57.369 HD Request # 2 | Requesting historical Daily data for B6Z19 starting at 2019-11-21 | 2019-11-26 18:40:57.373 6BZ19_FUT_CME #5 | StartDateTimeForLoadingOrderFills: 2019-11-20 15:29:53 | 2019-11-26 18:40:57.375 6BZ19_FUT_CME [C] 1 Day #9 | StartDateTimeForLoadingOrderFills: 2019-10-23 21:30:00 | 2019-11-26 18:40:57.379 6EZ19_FUT_CME #5 | StartDateTimeForLoadingOrderFills: 2019-11-23 23:19:55 | 2019-11-26 18:40:57.380 6BZ19_FUT_CME #3 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 18:40:57.381 6BZ19_FUT_CME 30 Min #1 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 18:40:57.420 6BZ19_FUT_CME 1000 Volume #7 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 18:40:57.437 6BZ19_FUT_CME 5 Min #6 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 18:40:57.440 6BZ19_FUT_CME 0.0010 Range #2 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 18:40:57.576 6EZ19_FUT_CME [C] 1 Day #9 | StartDateTimeForLoadingOrderFills: 2019-10-27 21:30:00 | 2019-11-26 18:40:57.578 ESZ19_FUT_CME #5 | StartDateTimeForLoadingOrderFills: 2019-11-23 23:19:57 | 2019-11-26 18:40:57.581 6EZ19_FUT_CME 30 Min #1 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 18:40:57.584 6EZ19_FUT_CME #3 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:01:00 | 2019-11-26 18:40:57.604 6EZ19_FUT_CME 1000 Volume #12 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:01:46 | 2019-11-26 18:40:57.646 6EZ19_FUT_CME 60 Min #2 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 18:40:57.650 6EZ19_FUT_CME 0.00050 Range #8 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:01:46 | 2019-11-26 18:40:57.652 6EZ19_FUT_CME 5 Min #10 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 18:40:57.656 MESZ19_FUT_CME 15 Min #8 | StartDateTimeForLoadingOrderFills: 2019-10-27 17:00:00 | 2019-11-26 18:40:57.794 ESZ19_FUT_CME #7 | StartDateTimeForLoadingOrderFills: 2019-11-23 23:19:57 | 2019-11-26 18:40:57.802 6EZ19_FUT_CME 5 Min #6 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 18:40:57.810 6EZ19_FUT_CME 240 Min #7 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 18:41:01.646 ESZ19_FUT_CME 5 Min #3 | StartDateTimeForLoadingOrderFills: 2019-10-28 06:00:00 | 2019-11-26 18:41:01.647 ESZ19_FUT_CME [C] 5 Min #4 | StartDateTimeForLoadingOrderFills: 2019-10-28 06:00:00 | 2019-11-26 18:41:03.283 HD Request # 2 | Receiving historical Daily data for 6BZ19_FUT_CME starting at 2019-11-22 | 2019-11-26 18:41:03.750 HD Request # 2 | Writing historical Daily data to the file 6BZ19_FUT_CME.dly | 2019-11-26 18:41:03.750 HD Request # 2 | Received 4 records from 2019-11-22 00:00:00 to 2019-11-26 00:00:00 (5.0 days) and wrote 3 records for 6BZ19_FUT_CME | 2019-11-26 18:41:03.761 HD Request # 2 | Completion time: 6s | 2019-11-26 18:41:03.772 HD Request # 2 | Daily data download complete for 6BZ19_FUT_CME. Unique request ID: 1 | 2019-11-26 18:41:03.772 Removing historical data download ID 1. | 2019-11-26 18:41:03.772 Triggering next historical data download in queue. | 2019-11-26 18:41:03.772 Mapping 6EZ19_FUT_CME to 6EZ19. Service code: cme | 2019-11-26 18:41:03.773 HD Request # 3 | Downloading Historical Daily chart data for 6EZ19_FUT_CME. Starting date: 2019-11-22. Service: sc_futures.dtc.trading | 2019-11-26 18:41:03.774 HD Request # 3 | Requesting historical Daily data for E6Z19 starting at 2019-11-21 | 2019-11-26 18:41:03.774 SC Data - All Services | Starting real-time market data updates for: 6BZ19_FUT_CME (6BZ19). ID: 1 Service code: cme | 2019-11-26 18:41:03.782 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2019-11-26 18:41:03.782 SC Data - All Services | Requesting security definition data for: 6BZ19_FUT_CME (6BZ19). ID: 1 | 2019-11-26 18:41:03.782 Starting DelayedDownloadMonitoringTimer | 2019-11-26 18:41:03.782 Starting HDTimeoutTimer | 2019-11-26 18:41:03.782 Added historical Intraday data request for 6BZ19_FUT_CME to the queue. | 2019-11-26 18:41:03.782 Intraday data recording state for symbol 6BZ19_FUT_CME is set to download 'Pending'. | 2019-11-26 18:41:03.782 Triggering next historical data download in queue. | 2019-11-26 18:41:03.782 Delaying start of download for 6BZ19_FUT_CME | 2019-11-26 18:41:03.783 6BZ19_FUT_CME [C] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-11-26 18:41:03.784 6BZ19_FUT_CME [C] Daily #4 | Reloading chart. | 2019-11-26 18:41:03.785 6BZ19_FUT_CME 5 Min #6 | Reloading chart. | 2019-11-26 18:41:03.819 SC Data - All Services | Starting real-time market data updates for: 6EZ19_FUT_CME (6EZ19). ID: 2 Service code: cme | 2019-11-26 18:41:03.851 SC Data - All Services | Requesting security definition data for: 6EZ19_FUT_CME (6EZ19). ID: 2 | 2019-11-26 18:41:03.851 Added historical Intraday data request for 6EZ19_FUT_CME to the queue. | 2019-11-26 18:41:03.852 Intraday data recording state for symbol 6EZ19_FUT_CME is set to download 'Pending'. | 2019-11-26 18:41:03.852 Triggering next historical data download in queue. | 2019-11-26 18:41:03.852 Requesting market depth updates for: 6BZ19_FUT_CME if supported. | 2019-11-26 18:41:03.853 Separate subscription for market depth updates not supported. 6BZ19_FUT_CME | 2019-11-26 18:41:03.853 Requesting market depth updates for: 6EZ19_FUT_CME if supported. | 2019-11-26 18:41:03.853 Separate subscription for market depth updates not supported. 6EZ19_FUT_CME | 2019-11-26 18:41:03.853 Mapping ESZ19_FUT_CME to ESZ19. Service code: cme | 2019-11-26 18:41:03.853 SC Data - All Services | Starting real-time market data updates for: ESZ19_FUT_CME (ESZ19). ID: 3 Service code: cme | 2019-11-26 18:41:03.854 SC Data - All Services | Requesting security definition data for: ESZ19_FUT_CME (ESZ19). ID: 3 | 2019-11-26 18:41:03.854 Requesting market depth updates for: ESZ19_FUT_CME if supported. | 2019-11-26 18:41:03.854 Separate subscription for market depth updates not supported. ESZ19_FUT_CME | 2019-11-26 18:41:03.854 Mapping MESZ19_FUT_CME to MESZ19. Service code: cme | 2019-11-26 18:41:03.854 SC Data - All Services | Starting real-time market data updates for: MESZ19_FUT_CME (MESZ19). ID: 4 Service code: cme | 2019-11-26 18:41:03.854 SC Data - All Services | Requesting security definition data for: MESZ19_FUT_CME (MESZ19). ID: 4 | 2019-11-26 18:41:03.854 Requesting market depth updates for: MESZ19_FUT_CME if supported. | 2019-11-26 18:41:03.854 Separate subscription for market depth updates not supported. MESZ19_FUT_CME | 2019-11-26 18:41:03.854 6EZ19_FUT_CME 5 Min #10 | Reloading chart. | 2019-11-26 18:41:03.858 Added historical Intraday data request for ESZ19_FUT_CME to the queue. | 2019-11-26 18:41:03.892 Intraday data recording state for symbol ESZ19_FUT_CME is set to download 'Pending'. | 2019-11-26 18:41:03.892 Triggering next historical data download in queue. | 2019-11-26 18:41:03.905 ESZ19_FUT_CME 5 Min #3 | Reloading chart. | 2019-11-26 18:41:03.921 Added historical Intraday data request for MESZ19_FUT_CME to the queue. | 2019-11-26 18:41:03.946 Intraday data recording state for symbol MESZ19_FUT_CME is set to download 'Pending'. | 2019-11-26 18:41:03.946 Triggering next historical data download in queue. | 2019-11-26 18:41:03.946 SC Futures Order Routing/Data | Received security definition for symbol 6BZ19_FUT_CME | 2019-11-26 18:41:04.122 ESZ19_FUT_CME [C][M] 1 Day #2 | StartDateTimeForLoadingOrderFills: 2019-10-27 22:30:00 | 2019-11-26 18:41:04.212 SC Futures Order Routing/Data | Received security definition for symbol 6EZ19_FUT_CME | 2019-11-26 18:41:04.212 SC Futures Order Routing/Data | Received security definition for symbol ESZ19_FUT_CME | 2019-11-26 18:41:04.212 SC Futures Order Routing/Data | Received security definition for symbol MESZ19_FUT_CME | 2019-11-26 18:41:04.212 6BZ19_FUT_CME [C] Daily #4 | Reloading chart. | 2019-11-26 18:41:04.286 DTC Client socket (4) | Creating socket. | 2019-11-26 18:41:04.458 DTC Client socket (4) | Connecting to IP: 216.1.90.129. | 2019-11-26 18:41:04.458 SC Data - All Services | Connected to server. | 2019-11-26 18:41:04.684 SC Data - All Services | Starting socket receive thread. | 2019-11-26 18:41:04.684 SC Data - All Services | Sending encoding request to server: Binary VLS | 2019-11-26 18:41:04.684 Added historical Daily data request for 6BZ19_FUT_CME to the queue. | 2019-11-26 18:41:04.784 Triggering next historical data download in queue. | 2019-11-26 18:41:04.784 SC Data - All Services | Setting DTC encoding to Binary VLS | 2019-11-26 18:41:04.939 SC Data - All Services | Sending logon request message. | 2019-11-26 18:41:04.939 HD Request # 3 | Receiving historical Daily data for 6EZ19_FUT_CME starting at 2019-11-22 | 2019-11-26 18:41:05.370 HD Request # 3 | Writing historical Daily data to the file 6EZ19_FUT_CME.dly | 2019-11-26 18:41:05.370 HD Request # 3 | Received 4 records from 2019-11-22 00:00:00 to 2019-11-26 00:00:00 (5.0 days) and wrote 3 records for 6EZ19_FUT_CME | 2019-11-26 18:41:05.381 HD Request # 3 | Completion time: 2s | 2019-11-26 18:41:05.579 HD Request # 3 | Daily data download complete for 6EZ19_FUT_CME. Unique request ID: 2 | 2019-11-26 18:41:05.579 Removing historical data download ID 2. | 2019-11-26 18:41:05.579 Triggering next historical data download in queue. | 2019-11-26 18:41:05.579 HD Request # 4 | Downloading Historical Daily chart data for ESZ19_FUT_CME. Starting date: 2019-11-22. Service: sc_futures.dtc.trading | 2019-11-26 18:41:05.580 HD Request # 4 | Requesting historical Daily data for ESZ19 starting at 2019-11-21 | 2019-11-26 18:41:05.580 SC Data - All Services | Received logon response. | 2019-11-26 18:41:05.627 SC Data - All Services | Server Name: SC Realtime Server. | 2019-11-26 18:41:05.627 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2019-11-26 18:41:05.627 SC Data - All Services | Successfully connected. | 2019-11-26 18:41:05.627 SC Data - All Services | Trading is not supported. | 2019-11-26 18:41:05.627 SC Data - All Services | Restarting real-time data updates for symbol: 6BZ19_FUT_CME -> 6BZ19 | 2019-11-26 18:41:05.627 SC Data - All Services | Restarting real-time data updates for symbol: 6EZ19_FUT_CME -> 6EZ19 | 2019-11-26 18:41:05.627 SC Data - All Services | Restarting real-time data updates for symbol: ESZ19_FUT_CME -> ESZ19 | 2019-11-26 18:41:05.627 SC Data - All Services | Restarting real-time data updates for symbol: MESZ19_FUT_CME -> MESZ19 | 2019-11-26 18:41:05.627 6EZ19_FUT_CME [C] Daily #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-11-26 18:41:05.837 6EZ19_FUT_CME [C] Daily #4 | Reloading chart. | 2019-11-26 18:41:05.838 6EZ19_FUT_CME [C] Daily #4 | Reloading chart. | 2019-11-26 18:41:06.351 SC Data - All Services | Clearing market depth for 6BZ19_FUT_CME. | 2019-11-26 18:41:06.610 SC Data - All Services | Received security definition for symbol 6BZ19_FUT_CME | 2019-11-26 18:41:06.610 6BZ19_FUT_CME [C][M] Daily #4 | StartDateTimeForLoadingOrderFills: 2019-11-24 04:41:00 | 2019-11-26 18:41:06.784 Added historical Daily data request for 6EZ19_FUT_CME to the queue. | 2019-11-26 18:41:06.839 Triggering next historical data download in queue. | 2019-11-26 18:41:06.839 6EZ19_FUT_CME[M] 5 Min #10 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 18:41:06.959 HD Request # 4 | Receiving historical Daily data for ESZ19_FUT_CME starting at 2019-11-22 | 2019-11-26 18:41:07.034 HD Request # 4 | Writing historical Daily data to the file ESZ19_FUT_CME.dly | 2019-11-26 18:41:07.034 HD Request # 4 | Received 4 records from 2019-11-22 00:00:00 to 2019-11-26 00:00:00 (5.0 days) and wrote 3 records for ESZ19_FUT_CME | 2019-11-26 18:41:07.036 HD Request # 4 | Completion time: 2s | 2019-11-26 18:41:07.043 HD Request # 4 | Daily data download complete for ESZ19_FUT_CME. Unique request ID: 3 | 2019-11-26 18:41:07.043 Removing historical data download ID 3. | 2019-11-26 18:41:07.043 Triggering next historical data download in queue. | 2019-11-26 18:41:07.043 HD Request # 5 | Downloading Historical Daily chart data for 6BZ19_FUT_CME. Starting date: 2019-11-25. Service: sc_futures.dtc.trading | 2019-11-26 18:41:07.044 HD Request # 5 | Requesting historical Daily data for B6Z19 starting at 2019-11-24 | 2019-11-26 18:41:07.044 ESZ19_FUT_CME [C] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-11-26 18:41:07.313 ESZ19_FUT_CME [C] Daily #6 | Reloading chart. | 2019-11-26 18:41:07.314 ESZ19_FUT_CME [C] Daily #6 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2019-11-26 18:41:10.135 SC Data - All Services | Clearing market depth for 6EZ19_FUT_CME. | 2019-11-26 18:41:10.201 SC Data - All Services | Clearing market depth for ESZ19_FUT_CME. | 2019-11-26 18:41:10.201 SC Data - All Services | Clearing market depth for MESZ19_FUT_CME. | 2019-11-26 18:41:10.201 ESZ19_FUT_CME [C][M] 2.50 Range #7 | StartDateTimeForLoadingOrderFills: 2019-10-28 06:00:00 | 2019-11-26 18:41:10.202 HD Request # 5 | Receiving historical Daily data for 6BZ19_FUT_CME starting at 2019-11-25 | 2019-11-26 18:41:10.207 HD Request # 5 | Writing historical Daily data to the file 6BZ19_FUT_CME.dly | 2019-11-26 18:41:10.207 HD Request # 5 | Received 2 records from 2019-11-25 00:00:00 to 2019-11-26 00:00:00 (2.0 days) and wrote 2 records for 6BZ19_FUT_CME | 2019-11-26 18:41:10.218 HD Request # 5 | Completion time: 3s | 2019-11-26 18:41:10.227 HD Request # 5 | Daily data download complete for 6BZ19_FUT_CME. Unique request ID: 8 | 2019-11-26 18:41:10.227 Removing historical data download ID 8. | 2019-11-26 18:41:10.227 Triggering next historical data download in queue. | 2019-11-26 18:41:10.227 ESZ19_FUT_CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2019-10-28 06:00:00 | 2019-11-26 18:41:10.229 SC Data - All Services | Received security definition for symbol 6EZ19_FUT_CME | 2019-11-26 18:41:10.360 SC Data - All Services | Received security definition for symbol ESZ19_FUT_CME | 2019-11-26 18:41:10.360 SC Data - All Services | Received security definition for symbol MESZ19_FUT_CME | 2019-11-26 18:41:10.360 HD Request # 6 | Downloading Historical Daily chart data for 6EZ19_FUT_CME. Starting date: 2019-11-25. Service: sc_futures.dtc.trading | 2019-11-26 18:41:10.361 HD Request # 6 | Requesting historical Daily data for E6Z19 starting at 2019-11-24 | 2019-11-26 18:41:10.361 6BZ19_FUT_CME[M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 18:41:10.362 6EZ19_FUT_CME [C][M] Daily #4 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2019-11-26 18:41:10.454 6BZ19_FUT_CME [C][M] Daily #4 | Reloading chart. | 2019-11-26 18:41:10.489 6BZ19_FUT_CME [C][M] Daily #4 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2019-11-26 18:41:10.752 ESZ19_FUT_CME [C] Daily #6 | Reloading chart. | 2019-11-26 18:41:10.755 HD Request # 7 | Downloading Intraday chart data for 6BZ19_FUT_CME to the file 6BZ19_FUT_CME.scid. Service: cme | 2019-11-26 18:41:11.072 HD Request # 7 | Download start date-time: 2019-11-22 15:29:53.000 | 2019-11-26 18:41:11.072 HD Request # 7 | Using server: ds22.sierracharts.com port 10149 | 2019-11-26 18:41:11.072 ESZ19_FUT_CME [C] Daily #6 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2019-11-26 18:41:11.123 HD Request # 6 | Receiving historical Daily data for 6EZ19_FUT_CME starting at 2019-11-25 | 2019-11-26 18:41:12.037 HD Request # 6 | Writing historical Daily data to the file 6EZ19_FUT_CME.dly | 2019-11-26 18:41:12.037 HD Request # 6 | Received 2 records from 2019-11-25 00:00:00 to 2019-11-26 00:00:00 (2.0 days) and wrote 2 records for 6EZ19_FUT_CME | 2019-11-26 18:41:12.049 HD Request # 6 | Completion time: 2s | 2019-11-26 18:41:12.098 HD Request # 6 | Daily data download complete for 6EZ19_FUT_CME. Unique request ID: 9 | 2019-11-26 18:41:12.098 Removing historical data download ID 9. | 2019-11-26 18:41:12.098 Triggering next historical data download in queue. | 2019-11-26 18:41:12.098 Socket (5) | Creating socket. | 2019-11-26 18:41:12.121 Socket (5) | Connecting to IP: 208.185.224.129. | 2019-11-26 18:41:12.121 6EZ19_FUT_CME [C][M] Daily #4 | Reloading chart. | 2019-11-26 18:41:12.377 HD Request # 7 | Setting DTC encoding to Binary VLS | 2019-11-26 18:41:12.630 HD Request # 7 | Sending historical data logon request message. | 2019-11-26 18:41:12.630 6EZ19_FUT_CME [C][M] Daily #4 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2019-11-26 18:41:12.745 HD Request # 7 | Requesting Intraday data. Start date-time: 2019-11-22 15:29:53. Record interval: 0. Symbol: 6BZ19 | 2019-11-26 18:41:13.296 HD Request # 7 | Decompressing data. | 2019-11-26 18:41:13.547 ESZ19_FUT_CME[M] 5 Min #8 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 18:41:14.020 HD Request # 7 | Receiving Intraday data for 6BZ19_FUT_CME starting at 2019-11-22 15:29:53 | 2019-11-26 18:41:14.077 HD Request # 7 | Timestamp of first Intraday data file record written: 2019-11-22 15:30:40 | 2019-11-26 18:41:14.077 ESZ19_FUT_CME[M] 5 Min #8 | Reloading chart. | 2019-11-26 18:41:14.139 ESZ19_FUT_CME[M] 60 Min #10 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 18:41:14.517 ESZ19_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 18:41:16.469 ESZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 18:41:16.949 Socket (5) | CloseSocket call. | 2019-11-26 18:41:17.638 Socket (5) | Shutdown started. Waiting for graceful close. | 2019-11-26 18:41:17.638 Historical data download thread signaled to stop. | 2019-11-26 18:41:17.649 HD Request # 7 | Received 111452 records from 2019-11-22 15:29:53.000 to 2019-11-26 18:41:15.003 (4.1 days) and wrote 111450 records for 6BZ19_FUT_CME | 2019-11-26 18:41:17.650 Added 1 Time and Sales records to Intraday data file for 6BZ19_FUT_CME after download. | 2019-11-26 18:41:17.652 HD Request # 7 | Completion time: 6s | 2019-11-26 18:41:17.655 HD Request # 7 | Intraday data download complete for 6BZ19_FUT_CME. Unique request ID: 4 | 2019-11-26 18:41:17.655 Removing historical data download ID 4. | 2019-11-26 18:41:17.655 Real-time Intraday chart data file updates started for 6BZ19_FUT_CME | 2019-11-26 18:41:17.655 Intraday chart data file opened for 6BZ19_FUT_CME | 2019-11-26 18:41:17.655 Triggering next historical data download in queue. | 2019-11-26 18:41:17.655 HD Request # 8 | Downloading Intraday chart data for 6EZ19_FUT_CME to the file 6EZ19_FUT_CME.scid. Service: cme | 2019-11-26 18:41:17.655 HD Request # 8 | Download start date-time: 2019-11-25 23:19:55.000 | 2019-11-26 18:41:17.655 HD Request # 8 | Using server: ds21.sierracharts.com port 10150 | 2019-11-26 18:41:17.655 Socket (1) | Creating socket. | 2019-11-26 18:41:17.655 Socket (1) | Connecting to IP: 216.1.90.129. | 2019-11-26 18:41:17.655 ESZ19_FUT_CME[M] 1000 Volume #11 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:05 | 2019-11-26 18:41:17.795 ESZ19_FUT_CME[M] 1000 Volume #11 | Reloading chart. | 2019-11-26 18:41:17.878 Socket (5) | Socket gracefully closed by remote side. | 2019-11-26 18:41:17.890 Socket (5) | Closed. | 2019-11-26 18:41:17.890 HD Request # 8 | Setting DTC encoding to Binary VLS | 2019-11-26 18:41:18.111 HD Request # 8 | Sending historical data logon request message. | 2019-11-26 18:41:18.111 ESZ19_FUT_CME[M] 2.50 Range #9 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:05 | 2019-11-26 18:41:18.154 ESZ19_FUT_CME[M] 2.50 Range #9 | Reloading chart. | 2019-11-26 18:41:18.345 HD Request # 8 | Requesting Intraday data. Start date-time: 2019-11-25 23:19:55. Record interval: 0. Symbol: 6EZ19 | 2019-11-26 18:41:18.792 HD Request # 8 | Decompressing data. | 2019-11-26 18:41:19.019 ESZ19_FUT_CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 18:41:19.447 HD Request # 8 | Receiving Intraday data for 6EZ19_FUT_CME starting at 2019-11-25 23:19:55 | 2019-11-26 18:41:19.491 HD Request # 8 | Timestamp of first Intraday data file record written: 2019-11-25 23:20:02 | 2019-11-26 18:41:19.492 ESZ19_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 18:41:19.961 Socket (1) | CloseSocket call. | 2019-11-26 18:41:21.665 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-26 18:41:21.665 Historical data download thread signaled to stop. | 2019-11-26 18:41:21.665 HD Request # 8 | Received 47994 records from 2019-11-25 23:19:55.000 to 2019-11-26 18:41:02.000 (19.4 hours) and wrote 47989 records for 6EZ19_FUT_CME | 2019-11-26 18:41:21.665 HD Request # 8 | Completion time: 4s | 2019-11-26 18:41:21.669 HD Request # 8 | Intraday data download complete for 6EZ19_FUT_CME. Unique request ID: 5 | 2019-11-26 18:41:21.669 Removing historical data download ID 5. | 2019-11-26 18:41:21.669 Real-time Intraday chart data file updates started for 6EZ19_FUT_CME | 2019-11-26 18:41:21.669 Intraday chart data file opened for 6EZ19_FUT_CME | 2019-11-26 18:41:21.669 Triggering next historical data download in queue. | 2019-11-26 18:41:21.669 HD Request # 9 | Downloading Intraday chart data for ESZ19_FUT_CME to the file ESZ19_FUT_CME.scid. Service: cme | 2019-11-26 18:41:21.670 HD Request # 9 | Download start date-time: 2019-11-25 23:19:57.000 | 2019-11-26 18:41:21.670 HD Request # 9 | Using server: ds22.sierracharts.com port 10149 | 2019-11-26 18:41:21.670 Socket (3) | Creating socket. | 2019-11-26 18:41:21.670 Socket (3) | Connecting to IP: 208.185.224.129. | 2019-11-26 18:41:21.670 Socket (1) | Socket gracefully closed by remote side. | 2019-11-26 18:41:21.890 Socket (1) | Closed. | 2019-11-26 18:41:21.890 HD Request # 9 | Setting DTC encoding to Binary VLS | 2019-11-26 18:41:22.163 HD Request # 9 | Sending historical data logon request message. | 2019-11-26 18:41:22.163 HD Request # 9 | Requesting Intraday data. Start date-time: 2019-11-25 23:19:57. Record interval: 0. Symbol: ESZ19 | 2019-11-26 18:41:22.414 HD Request # 9 | Decompressing data. | 2019-11-26 18:41:22.660 ESZ19_FUT_CME[M] 5 Min #8 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 18:41:24.441 Opened cached Intraday file: F:\SierraChart\Data\6BZ19_FUT_CME.scid | 2019-11-26 18:41:24.944 ESZ19_FUT_CME[M] 1000 Volume #11 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:05 | 2019-11-26 18:41:26.908 HD Request # 9 | Receiving Intraday data for ESZ19_FUT_CME starting at 2019-11-25 23:19:57 | 2019-11-26 18:41:28.163 HD Request # 9 | Timestamp of first Intraday data file record written: 2019-11-25 23:19:57 | 2019-11-26 18:41:28.164 ESZ19_FUT_CME[M] 2.50 Range #9 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:05 | 2019-11-26 18:41:28.850 Opened cached Intraday file: F:\SierraChart\Data\6EZ19_FUT_CME.scid | 2019-11-26 18:41:29.947 Socket (3) | CloseSocket call. | 2019-11-26 18:41:50.030 Historical data download thread signaled to stop. | 2019-11-26 18:41:50.030 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-26 18:41:50.030 HD Request # 9 | Received 287206 records from 2019-11-25 23:19:57.000 to 2019-11-26 18:41:39.000 (19.4 hours) and wrote 287189 records for ESZ19_FUT_CME | 2019-11-26 18:41:50.030 Added 1 Time and Sales records to Intraday data file for ESZ19_FUT_CME after download. | 2019-11-26 18:41:50.033 HD Request # 9 | Completion time: 29s | 2019-11-26 18:41:50.035 HD Request # 9 | Intraday data download complete for ESZ19_FUT_CME. Unique request ID: 6 | 2019-11-26 18:41:50.035 Removing historical data download ID 6. | 2019-11-26 18:41:50.035 Real-time Intraday chart data file updates started for ESZ19_FUT_CME | 2019-11-26 18:41:50.035 Intraday chart data file opened for ESZ19_FUT_CME | 2019-11-26 18:41:50.035 Triggering next historical data download in queue. | 2019-11-26 18:41:50.035 HD Request # 10 | Downloading Intraday chart data for MESZ19_FUT_CME to the file MESZ19_FUT_CME.scid. Service: cme | 2019-11-26 18:41:50.035 HD Request # 10 | Download start date-time: 2019-11-25 23:19:57.000 | 2019-11-26 18:41:50.036 HD Request # 10 | Using server: ds21.sierracharts.com port 10150 | 2019-11-26 18:41:50.036 Socket (1) | Creating socket. | 2019-11-26 18:41:50.036 Socket (1) | Connecting to IP: 216.1.90.129. | 2019-11-26 18:41:50.036 Socket (3) | Socket gracefully closed by remote side. | 2019-11-26 18:41:50.277 Socket (3) | Closed. | 2019-11-26 18:41:50.277 HD Request # 10 | Setting DTC encoding to Binary VLS | 2019-11-26 18:41:50.450 HD Request # 10 | Sending historical data logon request message. | 2019-11-26 18:41:50.450 HD Request # 10 | Requesting Intraday data. Start date-time: 2019-11-25 23:19:57. Record interval: 0. Symbol: MESZ19 | 2019-11-26 18:41:51.679 HD Request # 10 | Decompressing data. | 2019-11-26 18:41:51.886 HD Request # 10 | Receiving Intraday data for MESZ19_FUT_CME starting at 2019-11-25 23:19:57 | 2019-11-26 18:41:53.184 HD Request # 10 | Timestamp of first Intraday data file record written: 2019-11-25 23:19:58 | 2019-11-26 18:41:53.185 Opened cached Intraday file: F:\SierraChart\Data\ESZ19_FUT_CME.scid | 2019-11-26 18:41:54.962 Socket (1) | CloseSocket call. | 2019-11-26 18:41:56.876 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-26 18:41:56.876 Historical data download thread signaled to stop. | 2019-11-26 18:41:56.879 HD Request # 10 | Received 53910 records from 2019-11-25 23:19:57.000 to 2019-11-26 18:41:31.001 (19.4 hours) and wrote 53909 records for MESZ19_FUT_CME | 2019-11-26 18:41:56.879 HD Request # 10 | Completion time: 6s | 2019-11-26 18:41:56.882 HD Request # 10 | Intraday data download complete for MESZ19_FUT_CME. Unique request ID: 7 | 2019-11-26 18:41:56.882 Removing historical data download ID 7. | 2019-11-26 18:41:56.882 Real-time Intraday chart data file updates started for MESZ19_FUT_CME | 2019-11-26 18:41:56.882 Intraday chart data file opened for MESZ19_FUT_CME | 2019-11-26 18:41:56.882 Triggering next historical data download in queue. | 2019-11-26 18:41:56.882 Socket (1) | Socket gracefully closed by remote side. | 2019-11-26 18:41:57.083 Socket (1) | Closed. | 2019-11-26 18:41:57.083 Opened cached Intraday file: F:\SierraChart\Data\MESZ19_FUT_CME.scid | 2019-11-26 18:42:14.974 6EZ19_FUT_CME[M] 15 Min #1 | Reloading chart. | 2019-11-26 18:47:18.012 6EZ19_FUT_CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2019-07-29 17:00:00 | 2019-11-26 18:47:19.556 File >> Disconnect selected. | 2019-11-26 18:59:30.952 DTC Client socket (2) | CloseSocket call. | 2019-11-26 18:59:30.966 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2019-11-26 18:59:30.966 DTC Client socket (4) | CloseSocket call. | 2019-11-26 18:59:30.972 DTC Client socket (4) | 707 bytes remaining in receive buffer when socket closed. | 2019-11-26 18:59:30.972 SC Data - All Services | Disconnected from the server. | 2019-11-26 18:59:30.972 SC Futures Order Routing/Data | Disconnected. | 2019-11-26 18:59:30.972 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2019-11-26 18:59:30.972 DTC Client socket (2) | Socket gracefully closed by remote side. | 2019-11-26 18:59:31.219 DTC Client socket (2) | Closed. | 2019-11-26 18:59:31.219 DTC Client socket (4) | Socket gracefully closed by remote side. | 2019-11-26 18:59:31.429 DTC Client socket (4) | Closed. | 2019-11-26 18:59:31.429 SC Futures Order Routing/Data | Connecting to the server futurestrading5.sierracharts.com. Port 443 | 2019-11-26 18:59:52.921 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2019-11-26 18:59:54.021 DTC Client socket (1) | Connecting to IP: 209.58.163.194. | 2019-11-26 18:59:54.022 SC Futures Order Routing/Data | Connected to server. | 2019-11-26 18:59:57.371 SC Futures Order Routing/Data | Starting socket receive thread. | 2019-11-26 18:59:57.371 SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-11-26 18:59:57.371 SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2019-11-26 18:59:58.430 SC Futures Order Routing/Data | Sending logon request message. | 2019-11-26 18:59:58.430 SC Futures Order Routing/Data | Received logon response. | 2019-11-26 18:59:58.785 SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2019-11-26 18:59:58.785 SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2019-11-26 18:59:58.785 SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2019-11-26 18:59:58.785 SC Futures Order Routing/Data | Trading is supported. | 2019-11-26 18:59:58.785 SC Futures Order Routing/Data | Order cancel and replace is supported. | 2019-11-26 18:59:58.785 SC Futures Order Routing/Data | OCO Orders supported. | 2019-11-26 18:59:58.785 SC Futures Order Routing/Data | Bracket Orders supported. | 2019-11-26 18:59:58.785 SC Futures Order Routing/Data | Connected to data and trading server. | 2019-11-26 18:59:58.785 Triggering next historical data download in queue. | 2019-11-26 18:59:58.785 Triggering next historical data download in queue. | 2019-11-26 18:59:58.785 Triggering next historical data download in queue. | 2019-11-26 18:59:58.785 Triggering next historical data download in queue. | 2019-11-26 18:59:58.785 Mapping ESZ19_FUT_CME to ESZ19. Service code: cme | 2019-11-26 18:59:58.827 SC Data - All Services | Starting real-time market data updates for: ESZ19_FUT_CME (ESZ19). ID: 1 Service code: cme | 2019-11-26 18:59:58.827 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2019-11-26 18:59:58.827 SC Data - All Services | Requesting security definition data for: ESZ19_FUT_CME (ESZ19). ID: 1 | 2019-11-26 18:59:58.827 DTC Client socket (2) | Creating socket. | 2019-11-26 18:59:58.827 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2019-11-26 18:59:58.827 Added historical Intraday data request for ESZ19_FUT_CME to the queue. | 2019-11-26 18:59:58.885 Intraday data recording state for symbol ESZ19_FUT_CME is set to download 'Pending'. | 2019-11-26 18:59:58.885 Triggering next historical data download in queue. | 2019-11-26 18:59:58.885 Delaying start of download for ESZ19_FUT_CME | 2019-11-26 18:59:58.895 Mapping 6BZ19_FUT_CME to 6BZ19. Service code: cme | 2019-11-26 18:59:58.997 SC Data - All Services | Starting real-time market data updates for: 6BZ19_FUT_CME (6BZ19). ID: 2 Service code: cme | 2019-11-26 18:59:58.997 SC Data - All Services | Requesting security definition data for: 6BZ19_FUT_CME (6BZ19). ID: 2 | 2019-11-26 18:59:58.997 Added historical Intraday data request for 6BZ19_FUT_CME to the queue. | 2019-11-26 18:59:58.997 Intraday data recording state for symbol 6BZ19_FUT_CME is set to download 'Pending'. | 2019-11-26 18:59:58.997 Triggering next historical data download in queue. | 2019-11-26 18:59:58.997 Mapping 6EZ19_FUT_CME to 6EZ19. Service code: cme | 2019-11-26 18:59:58.999 SC Data - All Services | Starting real-time market data updates for: 6EZ19_FUT_CME (6EZ19). ID: 3 Service code: cme | 2019-11-26 18:59:58.999 SC Data - All Services | Requesting security definition data for: 6EZ19_FUT_CME (6EZ19). ID: 3 | 2019-11-26 18:59:58.999 Added historical Intraday data request for 6EZ19_FUT_CME to the queue. | 2019-11-26 18:59:58.999 Intraday data recording state for symbol 6EZ19_FUT_CME is set to download 'Pending'. | 2019-11-26 18:59:58.999 Triggering next historical data download in queue. | 2019-11-26 18:59:58.999 SC Data - All Services | Connected to server. | 2019-11-26 18:59:59.080 SC Data - All Services | Starting socket receive thread. | 2019-11-26 18:59:59.080 SC Data - All Services | Sending encoding request to server: Binary VLS | 2019-11-26 18:59:59.080 Mapping MESZ19_FUT_CME to MESZ19. Service code: cme | 2019-11-26 18:59:59.265 SC Data - All Services | Starting real-time market data updates for: MESZ19_FUT_CME (MESZ19). ID: 4 Service code: cme | 2019-11-26 18:59:59.265 SC Data - All Services | Requesting security definition data for: MESZ19_FUT_CME (MESZ19). ID: 4 | 2019-11-26 18:59:59.265 Added historical Intraday data request for MESZ19_FUT_CME to the queue. | 2019-11-26 18:59:59.265 Intraday data recording state for symbol MESZ19_FUT_CME is set to download 'Pending'. | 2019-11-26 18:59:59.265 Triggering next historical data download in queue. | 2019-11-26 18:59:59.265 SC Data - All Services | Setting DTC encoding to Binary VLS | 2019-11-26 18:59:59.365 SC Data - All Services | Sending logon request message. | 2019-11-26 18:59:59.365 SC Futures Order Routing/Data | Received security definition for symbol ESZ19_FUT_CME | 2019-11-26 18:59:59.917 SC Futures Order Routing/Data | Received security definition for symbol 6BZ19_FUT_CME | 2019-11-26 18:59:59.917 SC Futures Order Routing/Data | Received security definition for symbol 6EZ19_FUT_CME | 2019-11-26 18:59:59.917 SC Futures Order Routing/Data | Received security definition for symbol MESZ19_FUT_CME | 2019-11-26 18:59:59.917 SC Data - All Services | Received logon response. | 2019-11-26 19:00:00.066 SC Data - All Services | Server Name: SC Realtime Server. | 2019-11-26 19:00:00.066 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2019-11-26 19:00:00.066 SC Data - All Services | Successfully connected. | 2019-11-26 19:00:00.066 SC Data - All Services | Trading is not supported. | 2019-11-26 19:00:00.066 SC Data - All Services | Restarting real-time data updates for symbol: 6BZ19_FUT_CME -> 6BZ19 | 2019-11-26 19:00:00.066 SC Data - All Services | Restarting real-time data updates for symbol: 6EZ19_FUT_CME -> 6EZ19 | 2019-11-26 19:00:00.066 SC Data - All Services | Restarting real-time data updates for symbol: ESZ19_FUT_CME -> ESZ19 | 2019-11-26 19:00:00.066 SC Data - All Services | Restarting real-time data updates for symbol: MESZ19_FUT_CME -> MESZ19 | 2019-11-26 19:00:00.066 SC Data - All Services | Received security definition for symbol 6BZ19_FUT_CME | 2019-11-26 19:00:00.362 SC Data - All Services | Received security definition for symbol 6EZ19_FUT_CME | 2019-11-26 19:00:00.362 SC Data - All Services | Received security definition for symbol ESZ19_FUT_CME | 2019-11-26 19:00:00.362 SC Data - All Services | Received security definition for symbol MESZ19_FUT_CME | 2019-11-26 19:00:00.362 Requesting market depth updates for: 6BZ19_FUT_CME if supported. | 2019-11-26 19:00:03.775 Requesting market depth updates for: 6EZ19_FUT_CME if supported. | 2019-11-26 19:00:03.775 Requesting market depth updates for: ESZ19_FUT_CME if supported. | 2019-11-26 19:00:03.775 Requesting market depth updates for: MESZ19_FUT_CME if supported. | 2019-11-26 19:00:03.775 SC Data - All Services | Clearing market depth for 6BZ19_FUT_CME. | 2019-11-26 19:00:04.285 SC Data - All Services | Clearing market depth for 6EZ19_FUT_CME. | 2019-11-26 19:00:04.285 SC Data - All Services | Clearing market depth for ESZ19_FUT_CME. | 2019-11-26 19:00:04.285 SC Data - All Services | Clearing market depth for MESZ19_FUT_CME. | 2019-11-26 19:00:04.285 HD Request # 11 | Downloading Intraday chart data for ESZ19_FUT_CME to the file ESZ19_FUT_CME.scid. Service: cme | 2019-11-26 19:00:05.807 HD Request # 11 | Download start date-time: 2019-11-26 18:59:12.000 | 2019-11-26 19:00:05.807 HD Request # 11 | Using server: ds22.sierracharts.com port 10149 | 2019-11-26 19:00:05.808 Socket (3) | Creating socket. | 2019-11-26 19:00:05.808 Socket (3) | Connecting to IP: 208.185.224.129. | 2019-11-26 19:00:05.808 HD Request # 11 | Setting DTC encoding to Binary VLS | 2019-11-26 19:00:06.277 HD Request # 11 | Sending historical data logon request message. | 2019-11-26 19:00:06.277 HD Request # 11 | Requesting Intraday data. Start date-time: 2019-11-26 18:59:12. Record interval: 0. Symbol: ESZ19 | 2019-11-26 19:00:07.551 HD Request # 11 | Decompressing data. | 2019-11-26 19:00:07.786 HD Request # 11 | Receiving Intraday data for ESZ19_FUT_CME starting at 2019-11-26 18:59:12 | 2019-11-26 19:00:07.786 HD Request # 11 | Timestamp of first Intraday data file record written: 2019-11-26 18:59:34 | 2019-11-26 19:00:07.787 Socket (3) | CloseSocket call. | 2019-11-26 19:00:07.787 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-26 19:00:07.787 Historical data download thread signaled to stop. | 2019-11-26 19:00:07.787 HD Request # 11 | Received 23 records from 2019-11-26 18:59:12.000 to 2019-11-26 18:59:58.001 (46.0 seconds) and wrote 22 records for ESZ19_FUT_CME | 2019-11-26 19:00:07.788 HD Request # 11 | Completion time: 2s | 2019-11-26 19:00:07.794 HD Request # 11 | Intraday data download complete for ESZ19_FUT_CME. Unique request ID: 10 | 2019-11-26 19:00:07.794 Removing historical data download ID 10. | 2019-11-26 19:00:07.794 Real-time Intraday chart data file updates started for ESZ19_FUT_CME | 2019-11-26 19:00:07.794 Intraday chart data file opened for ESZ19_FUT_CME | 2019-11-26 19:00:07.794 Triggering next historical data download in queue. | 2019-11-26 19:00:07.794 HD Request # 12 | Downloading Intraday chart data for 6BZ19_FUT_CME to the file 6BZ19_FUT_CME.scid. Service: cme | 2019-11-26 19:00:07.794 HD Request # 12 | Download start date-time: 2019-11-26 18:59:30.000 | 2019-11-26 19:00:07.794 HD Request # 12 | Using server: ds21.sierracharts.com port 10150 | 2019-11-26 19:00:07.794 Socket (4) | Creating socket. | 2019-11-26 19:00:07.795 Socket (4) | Connecting to IP: 216.1.90.129. | 2019-11-26 19:00:07.795 Socket (3) | Socket gracefully closed by remote side. | 2019-11-26 19:00:08.018 Socket (3) | Closed. | 2019-11-26 19:00:08.018 HD Request # 12 | Setting DTC encoding to Binary VLS | 2019-11-26 19:00:08.260 HD Request # 12 | Sending historical data logon request message. | 2019-11-26 19:00:08.260 HD Request # 12 | Requesting Intraday data. Start date-time: 2019-11-26 18:59:30. Record interval: 0. Symbol: 6BZ19 | 2019-11-26 19:00:08.952 HD Request # 12 | Decompressing data. | 2019-11-26 19:00:09.186 HD Request # 12 | Receiving Intraday data for 6BZ19_FUT_CME starting at 2019-11-26 18:59:30 | 2019-11-26 19:00:09.186 HD Request # 12 | Timestamp of first Intraday data file record written: 2019-11-26 18:59:37 | 2019-11-26 19:00:09.186 Socket (4) | CloseSocket call. | 2019-11-26 19:00:09.186 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-11-26 19:00:09.186 Historical data download thread signaled to stop. | 2019-11-26 19:00:09.186 HD Request # 12 | Received 32 records from 2019-11-26 18:59:30.000 to 2019-11-26 19:00:04.011 (34.0 seconds) and wrote 31 records for 6BZ19_FUT_CME | 2019-11-26 19:00:09.186 HD Request # 12 | Completion time: 2s | 2019-11-26 19:00:09.189 HD Request # 12 | Intraday data download complete for 6BZ19_FUT_CME. Unique request ID: 11 | 2019-11-26 19:00:09.189 Removing historical data download ID 11. | 2019-11-26 19:00:09.189 Real-time Intraday chart data file updates started for 6BZ19_FUT_CME | 2019-11-26 19:00:09.189 Intraday chart data file opened for 6BZ19_FUT_CME | 2019-11-26 19:00:09.189 Triggering next historical data download in queue. | 2019-11-26 19:00:09.189 HD Request # 13 | Downloading Intraday chart data for 6EZ19_FUT_CME to the file 6EZ19_FUT_CME.scid. Service: cme | 2019-11-26 19:00:09.189 HD Request # 13 | Download start date-time: 2019-11-26 18:59:30.000 | 2019-11-26 19:00:09.189 HD Request # 13 | Using server: ds22.sierracharts.com port 10149 | 2019-11-26 19:00:09.189 Socket (3) | Creating socket. | 2019-11-26 19:00:09.189 Socket (3) | Connecting to IP: 208.185.224.129. | 2019-11-26 19:00:09.189 HD Request # 13 | Setting DTC encoding to Binary VLS | 2019-11-26 19:00:09.724 HD Request # 13 | Sending historical data logon request message. | 2019-11-26 19:00:09.724 Socket (4) | Socket gracefully closed by remote side. | 2019-11-26 19:00:09.917 Socket (4) | Closed. | 2019-11-26 19:00:09.917 HD Request # 13 | Requesting Intraday data. Start date-time: 2019-11-26 18:59:30. Record interval: 0. Symbol: 6EZ19 | 2019-11-26 19:00:09.993 HD Request # 13 | Decompressing data. | 2019-11-26 19:00:10.263 HD Request # 13 | Receiving Intraday data for 6EZ19_FUT_CME starting at 2019-11-26 18:59:30 | 2019-11-26 19:00:10.263 HD Request # 13 | Timestamp of first Intraday data file record written: 2019-11-26 18:59:30 | 2019-11-26 19:00:10.264 Socket (3) | CloseSocket call. | 2019-11-26 19:00:10.264 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-26 19:00:10.264 Historical data download thread signaled to stop. | 2019-11-26 19:00:10.264 HD Request # 13 | Received 24 records from 2019-11-26 18:59:30.000 to 2019-11-26 19:00:06.002 (36.0 seconds) and wrote 15 records for 6EZ19_FUT_CME | 2019-11-26 19:00:10.264 HD Request # 13 | Completion time: 0s | 2019-11-26 19:00:10.267 HD Request # 13 | Intraday data download complete for 6EZ19_FUT_CME. Unique request ID: 12 | 2019-11-26 19:00:10.267 Removing historical data download ID 12. | 2019-11-26 19:00:10.267 Real-time Intraday chart data file updates started for 6EZ19_FUT_CME | 2019-11-26 19:00:10.267 Intraday chart data file opened for 6EZ19_FUT_CME | 2019-11-26 19:00:10.267 Triggering next historical data download in queue. | 2019-11-26 19:00:10.267 HD Request # 14 | Downloading Intraday chart data for MESZ19_FUT_CME to the file MESZ19_FUT_CME.scid. Service: cme | 2019-11-26 19:00:10.267 HD Request # 14 | Download start date-time: 2019-11-26 18:59:21.000 | 2019-11-26 19:00:10.267 HD Request # 14 | Using server: ds21.sierracharts.com port 10150 | 2019-11-26 19:00:10.267 Socket (4) | Creating socket. | 2019-11-26 19:00:10.267 Socket (4) | Connecting to IP: 216.1.90.129. | 2019-11-26 19:00:10.267 Socket (3) | Socket gracefully closed by remote side. | 2019-11-26 19:00:10.529 Socket (3) | Closed. | 2019-11-26 19:00:10.529 HD Request # 14 | Setting DTC encoding to Binary VLS | 2019-11-26 19:00:10.745 HD Request # 14 | Sending historical data logon request message. | 2019-11-26 19:00:10.745 HD Request # 14 | Requesting Intraday data. Start date-time: 2019-11-26 18:59:21. Record interval: 0. Symbol: MESZ19 | 2019-11-26 19:00:10.983 HD Request # 14 | Decompressing data. | 2019-11-26 19:00:11.222 HD Request # 14 | Receiving Intraday data for MESZ19_FUT_CME starting at 2019-11-26 18:59:21 | 2019-11-26 19:00:11.222 HD Request # 14 | Timestamp of first Intraday data file record written: 2019-11-26 18:59:56 | 2019-11-26 19:00:11.223 Socket (4) | CloseSocket call. | 2019-11-26 19:00:11.223 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-11-26 19:00:11.223 Historical data download thread signaled to stop. | 2019-11-26 19:00:11.223 HD Request # 14 | Received 7 records from 2019-11-26 18:59:21.000 to 2019-11-26 19:00:01.001 (40.0 seconds) and wrote 5 records for MESZ19_FUT_CME | 2019-11-26 19:00:11.223 HD Request # 14 | Completion time: 0s | 2019-11-26 19:00:11.226 HD Request # 14 | Intraday data download complete for MESZ19_FUT_CME. Unique request ID: 13 | 2019-11-26 19:00:11.226 Removing historical data download ID 13. | 2019-11-26 19:00:11.226 Real-time Intraday chart data file updates started for MESZ19_FUT_CME | 2019-11-26 19:00:11.226 Intraday chart data file opened for MESZ19_FUT_CME | 2019-11-26 19:00:11.226 Triggering next historical data download in queue. | 2019-11-26 19:00:11.226 Socket (4) | Socket gracefully closed by remote side. | 2019-11-26 19:00:11.460 Socket (4) | Closed. | 2019-11-26 19:00:11.460 Opened cached Intraday file: F:\SierraChart\Data\ESZ19_FUT_CME.scid | 2019-11-26 19:00:15.531 Opened cached Intraday file: F:\SierraChart\Data\6BZ19_FUT_CME.scid | 2019-11-26 19:00:15.531 Opened cached Intraday file: F:\SierraChart\Data\MESZ19_FUT_CME.scid | 2019-11-26 19:00:20.534 Opened cached Intraday file: F:\SierraChart\Data\6EZ19_FUT_CME.scid | 2019-11-26 19:00:25.537 ESZ19_FUT_CME[M] 5 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.719 6BZ19_FUT_CME [C][M] 1 Day #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.766 ESZ19_FUT_CME[M] 60 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.766 6EZ19_FUT_CME[M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.795 ESZ19_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.795 6EZ19_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.842 MESZ19_FUT_CME[M] 15 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.842 ESZ19_FUT_CME [C][M] Daily #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.843 ESZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.927 6EZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.927 ESZ19_FUT_CME[M] 1000 Volume #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.927 ESZ19_FUT_CME[M] 2.50 Range #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:41.939 6BZ19_FUT_CME[M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.004 6EZ19_FUT_CME[M] 240 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.006 ESZ19_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.007 6EZ19_FUT_CME[M] 5 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.007 6BZ19_FUT_CME[M] 0.0010 Range #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.068 6EZ19_FUT_CME [C][M] Daily #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.069 6BZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.069 6EZ19_FUT_CME[M] 1000 Volume #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.069 ESZ19_FUT_CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.070 6EZ19_FUT_CME[M] 0.00050 Range #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.070 6EZ19_FUT_CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.071 ESZ19_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.071 6BZ19_FUT_CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.083 6BZ19_FUT_CME[M] 1000 Volume #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.083 ESZ19_FUT_CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.084 6BZ19_FUT_CME [C][M] Daily #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.188 ESZ19_FUT_CME [C][M] 2.50 Range #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.198 ESZ19_FUT_CME [C][M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.198 ESZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.198 6EZ19_FUT_CME[M] 60 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.262 6EZ19_FUT_CME [C][M] 1 Day #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.262 ESZ19_FUT_CME [C][M] 1 Day #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.262 6BZ19_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-26 19:16:42.263 6EZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 2019-11-24 22:28:36 | 2019-11-26 22:28:46.944 6BZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 2019-11-22 00:00:00 | 2019-11-26 22:28:46.945 6BZ19_FUT_CME[M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 22:28:46.945 6EZ19_FUT_CME[M] 240 Min #7 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 22:28:46.948 ESZ19_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 22:28:46.948 6EZ19_FUT_CME[M] 5 Min #10 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 22:28:46.949 6BZ19_FUT_CME[M] 0.0010 Range #2 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 22:28:46.952 6EZ19_FUT_CME [C][M] Daily #4 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2019-11-26 22:28:46.953 ESZ19_FUT_CME[M] 1000 Volume #11 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:05 | 2019-11-26 22:28:46.953 ESZ19_FUT_CME[M] 2.50 Range #9 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:05 | 2019-11-26 22:28:46.965 6EZ19_FUT_CME[M] 1000 Volume #12 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:01:46 | 2019-11-26 22:28:46.981 ESZ19_FUT_CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2019-10-28 06:00:00 | 2019-11-26 22:28:46.982 6EZ19_FUT_CME[M] 0.00050 Range #8 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:01:46 | 2019-11-26 22:28:46.983 6EZ19_FUT_CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2019-07-29 17:00:00 | 2019-11-26 22:28:47.026 ESZ19_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 22:28:47.027 6BZ19_FUT_CME[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 22:28:47.037 6BZ19_FUT_CME[M] 1000 Volume #7 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 22:28:47.038 ESZ19_FUT_CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 22:28:47.038 6BZ19_FUT_CME [C][M] Daily #4 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2019-11-26 22:28:47.055 ESZ19_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 2019-11-24 22:28:43 | 2019-11-26 22:28:47.056 ESZ19_FUT_CME [C][M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 2019-10-28 06:00:00 | 2019-11-26 22:28:47.074 ESZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 22:28:47.074 6EZ19_FUT_CME[M] 60 Min #2 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 22:28:47.091 ESZ19_FUT_CME [C][M] 2.50 Range #7 | StartDateTimeForLoadingOrderFills: 2019-10-28 06:00:00 | 2019-11-26 22:28:47.091 ESZ19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 2019-11-24 22:28:43 | 2019-11-26 22:28:47.134 6EZ19_FUT_CME [C][M] 1 Day #9 | StartDateTimeForLoadingOrderFills: 2019-10-27 21:30:00 | 2019-11-26 22:28:47.149 ESZ19_FUT_CME [C][M] 1 Day #2 | StartDateTimeForLoadingOrderFills: 2019-10-27 22:30:00 | 2019-11-26 22:28:47.149 6BZ19_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 2019-07-26 01:30:00 | 2019-11-26 22:28:47.149 6BZ19_FUT_CME [C][M] 1 Day #9 | StartDateTimeForLoadingOrderFills: 2019-10-23 21:30:00 | 2019-11-26 22:28:47.223 ESZ19_FUT_CME[M] 60 Min #10 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 22:28:47.223 6EZ19_FUT_CME[M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:00:00 | 2019-11-26 22:28:47.236 ESZ19_FUT_CME[M] 5 Min #8 | StartDateTimeForLoadingOrderFills: 2019-08-27 19:00:00 | 2019-11-26 22:28:47.237 6EZ19_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 2019-07-28 17:01:00 | 2019-11-26 22:28:47.304 MESZ19_FUT_CME[M] 15 Min #8 | StartDateTimeForLoadingOrderFills: 2019-10-27 17:00:00 | 2019-11-26 22:28:47.305 ESZ19_FUT_CME [C][M] Daily #6 | StartDateTimeForLoadingOrderFills: 2016-11-28 00:00:00 | 2019-11-26 22:28:47.385 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-11-26 22:34:06.009 DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-11-26 22:34:06.009 * DTC Client socket (1) | CloseSocket call. | 2019-11-26 22:34:06.010 Connection to the external service has been lost. | 2019-11-26 22:34:06.010 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-11-26 22:34:06.010 DTC Client socket (1) | Closed. | 2019-11-26 22:34:06.010 DTC Client socket (0) | CloseSocket call. | 2019-11-26 22:34:06.027 SC Futures Order Routing/Data | Disconnected. | 2019-11-26 22:34:06.027 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-11-26 22:34:06.027 SC Futures Order Routing/Data | Connecting to the server futurestrading5.sierracharts.com. Port 443 | 2019-11-26 22:34:07.111 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2019-11-26 22:34:07.417 DTC Client socket (1) | Connecting to IP: 209.58.163.194. | 2019-11-26 22:34:07.417 SC Futures Order Routing/Data | Connected to server. | 2019-11-26 22:34:07.744 SC Futures Order Routing/Data | Starting socket receive thread. | 2019-11-26 22:34:07.744 SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-11-26 22:34:07.744 |
[2019-11-27 03:24:08] |
You are losing the connection to the Singapore trading server: DTC Client socket (1) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-11-26 22:34:06.009 *
SC Futures Order Routing/Data | Disconnected. | 2019-11-26 22:34:06.027 Set Global Settings >> Data/Trade Service Settings >> Service Setting >> Primary Server to: Server 3 We will do our best to help with this. We just want to see if this other server will help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-27 03:24:37
