Date/Time: Sun, 19 May 2024 00:36:57 +0000
US Forex
View Count: 1124
[2019-11-24 18:38:04] |
User625613 - Posts: 6 |
Hello SierraChart, Is there a data feed to US forex broker available, other than IB? It looks like there are only a couple choices for us clients. oanda and gain(forex.com). How would i go about getting the data into sierra chart please? A few comments were found on the message board but they all were a year or two old. Thanks |
[2019-11-25 04:01:17] |
No none of this is supported. Oanda is below our technical standard and we would never integrate to them. Despite the technical problems with Interactive Brokers, they are still overall the best. And if you are just interested in data, you might as well just simply use this data feed: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
