Date/Time: Sat, 19 Sep 2026 12:19:06 +0000
[User Discussion] - spreadsheet problem
View Count: 2732
[2013-12-23 22:47:41]
toews&kane - Posts: 209
Hi there,
Trying to work on this problem for a bit now.
I am trying to restrict one condition for this time frame
$H$8 =AND(J41-INT(J41)>=TIMEVALUE("13:00:00"),J41-INT(J41)<TIMEVALUE("14:00:00"))
with column x refering to it
IF($H$8, SOME CONDITION, PREVIOUS CELL VALUE)
so that once the condition is met say B3<=-10 it will be flagged true for the rest of the day
how do i do this?
[2013-12-24 00:33:06]
Sawtooth - Posts: 4354
If your formula goes TRUE between the TIMEVALUEs, it won't necessarily stay TRUE.
Take a look at this solution:
http://www.sawtoothtrade.com/example-9.html
Let me know if you need more help.
Date Time Of Last Edit: 2015-08-14 01:48:44
[2013-12-24 01:03:11]
Bedhog - Posts: 187
How many Rows in Column H are available for setting state like this?
[2013-12-24 02:43:53]
@tom works like a gem thanks
@bedhog I think H,I, J are the only column that doesn't scroll so as many rows as you have I guess, or you can do a test I've never tried the max rows it will take
[2013-12-24 23:17:43]
I am finding a problem
H8 holds =AND(J41-INT(J41)>=TIMEVALUE("13:00:00"),J41-INT(J41)<TIMEVALUE("14:00:00"))
H9 holds =AND(OR(AND(H8=TRUE, CT3<=-4000),H10>1),H11=FALSE)
H10 holds a counter to hold the condition true
=IF($H$8=TRUE, H10+1,IF(INT(A3)>INT(A4), 1, H10))
H11 is the release on the lock
=INT(A3)>INT(A4)
The issue is H9 goes to true automatically without evaluation ct3<=-4000. how can that happen?
[2013-12-25 01:30:29]
I think the locking formula should be this:
=AND(OR(H9=TRUE,AND(CT3<=-4000,H10>1)),H11=FALSE)
The locking TRUE formula should reference its own cell (H9), and the second part of the OR statement is the condition that initiates the TRUE.
[2013-12-26 01:59:59]
my bad, I know what happened I wasn't referencing to the locking true formula, thanks
