Date/Time: Sun, 19 May 2024 03:15:23 +0000
Limit orders, leaving stop loss order after close
View Count: 694
[2019-11-24 13:20:35] |
user_Irm - Posts: 1 |
Hi. I am trying to place Limit bracket orders only with Stop Loss. After closing it manually or with opposite limit order, Stop Loss orders are left as active entry/stop orders. I want that they cancel. I tried to play around and find correct order type to do so, however no success. Can you please suggest what settings to use? Regards |
[2019-11-25 03:35:36] |
First make sure that you are using Attached Orders for the Stop Order: Attached Orders And when you want to close the position use Flatten and Cancel: Basic Trading and the Trade Window: Main/C >> Flatten (Flatten and Cancel) Or use Scale Out: Attached Orders: Scaling Out Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
