Date/Time: Mon, 03 Feb 2025 14:11:01 +0000
Switch from AMP to SC direct
View Count: 583
[2019-11-24 12:25:00] |
User938731 - Posts: 16 |
Hey guys. At the moment I use your fabulous platform via AMP. I want to swicht to using you directly. I already funded my account here. I can't find a way to do this in the account management. Do I have to arrange this with AMP? And do I get to keep the same account nr with you guys? Tnx in advance. Greetz, Morris |
[2019-11-24 15:03:07] |
You first need to ask AMP to remove from your AMP account the providing of Sierra Chart Advanced package. And when that is done let us know.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-24 15:03:21
