Date/Time: Sun, 19 May 2024 00:37:04 +0000
EURUSD chart is same as EURUSD-ASK
View Count: 473
[2019-11-24 08:58:44] |
phaedonk - Posts: 352 |
Why is that? It is supposed to be a Bid Ask average, yet it is the same, tick for tick, with the ASK chart. (the BID chart is obviously quite different, about 0.00006 price difference) |
[2019-11-25 03:45:08] |
Sierra Chart does not maintain separate historical data for EURUSD-ASK. So it is the same as EURUSD. You can see that EURUSD is the average by just simply applying the Bid and Ask prices study: Bid & Ask Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
