Date/Time: Mon, 03 Feb 2025 13:51:58 +0000
SCString.AppendFormat() not being released in memory
View Count: 587
[2019-11-24 04:23:39] |
User735389 - Posts: 189 |
I found this issue while troubleshooting my other support thread "sc.fileclose() doesn't release memory". AppendFormat() specifically seems to be causing a memory leak. Running it in a loop, memory builds and isn't released after the SCString var is out of scope. Using Append(SCString().Format("")) instead causes no memory issues at all. Win 7 if that matters.
[2019-11-24 04:51:13] |
Yes we can confirm this is the case and it will be resolved in the next release.
