Date/Time: Mon, 03 Feb 2025 14:00:35 +0000
[Programming Help] - Zoom In/Out Key
View Count: 2162
[2019-11-24 03:06:50]
User659208 - Posts: 22
Is it possible to change the key for zooming in/out of chart?
My current zoom in/out is SHIFT + SCROLL IN/OUT
Will it be possible to change the key to just SCROLL IN/OUT?
[2019-11-24 04:09:56]
Refer to this setting:
General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll)
[2019-11-24 04:17:59]
Thanks a lot!!
[2019-11-24 18:43:55]
Hey one more question... Is there any way I can change the setting for dragging chart as well?
For example, I can drag the chart to the left/right to move the chart to left/right. However, the chart won't move to the top/bottom if i drag the chart up/down. I would have to drag the chart price to move the chart up/down. Can I change the setting for that to move the chart up/down on chart?
[2019-11-24 23:38:49]
Enable this option:
Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options)
