Date/Time: Mon, 03 Mar 2025 22:18:48 +0000
Recommended version of Windows
View Count: 1535
[2019-11-23 14:28:14] |
User50927 - Posts: 91 |
Engineering, I'm running Windows 7 on my computer but MS have recently informed us that they will discontinue its support early next year, so my question is: What newer version of the software works best with your software based on first-hand experience? Thanks. |
[2019-11-23 14:36:42] |
We recommend just continuing with Windows 7. That should be fine for another two years. And by then, Sierra Chart will definitely be supporting Linux directly. No reason to be changing unless the hardware you are running requires a more up-to-date operating system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-23 14:37:28
[2021-06-23 18:10:22] |
User783093 - Posts: 27 |
Is there a chance we will get Mac/Linux version of Sierra this year?
Date Time Of Last Edit: 2021-06-23 18:10:34
[2021-06-24 20:14:20] |
Sierra_Chart Engineering - Posts: 18631 |
Not a native version. However, you can run Sierra Chart on a Mac now: https://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#UsingSierraChartOnMacOS The described set up we are told works well. Sierra Chart has already been changed significantly to allow it to work well under these translation layers. And we will continue to make improvement towards that. And under Linux you can use Wine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-24 20:14:27
[2021-06-24 20:19:21] |
I'm currently using CrossOver and it's far from perfect. Had to use Parallels which is also far from perfect. Pity to hear that you changed your plans to move from Windows...
[2021-11-16 23:50:17] |
kmistr01 - Posts: 2 |
Does Sierra charts work with Windows 11?
[2021-11-17 00:48:12] |
Yes.
[2021-11-17 01:03:33] |
Thank you
